Hi Jun-ichi,
On Wednesday 22 April 2009 07:47:51 [email protected] wrote:
> Thank you very much for the information.
> Just say "YES"...
> Is that all what I have to do?
Well, almost. Linux only allows processes to use the pthreads real-time
priorities if the process is sufficiently privileged (because it's easy to
code a Denial of Service attack to bring down the OS if you have that
privilege). There's probably a Capability (CAP_xx) that controls this, but I
don't know what it is. The easiest way to provide that is to run the IOC as
root, which I don't recommend on a general-use system for security reasons
but should be Ok on a dedicated machine.
There is a test program called epicsThreadPriorityTest that you can run from
your base/src/libCom/test/O.<arch> directory which tells you whether the
threads are being scheduled strictly by priority or not, so you should be
able to use that to experiment.
HTH,
- Andrew
> > > Dear All;
> > > I've recently come to notice that the real-time performance of Linux
> > > kernel is incredibly improving (against my expectations).
> > > http://www.osadl.org/Single-View.111+M5b96e97f67b.0.html
> > > I'd like to know if the implementation of OSD-library is implemented
> in
> > > such a manner that the kernel-level threads can reflect the priority
> > > given by the user to the scheduling of epicsThreads?
> > > In other words, can I benefit from the improvement of Linux kernel
> > > without making any changes in EPICS source codes?
> > in file base/configure/CONFIG_SITE
> > change
> > USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO
> > to
> > USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
> > Also you must start the IOC as root.
> > Marty
The best FOSS code is written to be read by other humans -- Harold Welte
- Re: Priorities of epicsThreads on Linux jun-ichi.odagiri
- Priorities of epicsThreads on Linux jun-ichi.odagiri
- Re: Priorities of epicsThreads on Linux Marty Kraimer
back propagating error states Leicester, PJ (Pete)
Re: back propagating error states Andrew Johnson
<2009>
<2009>
