1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Priorities of epicsThreads on Linux
To: "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Thu, 23 Apr 2009 05:46:55 +0900
Hi Andrew,
Thank you VERY MUCH for your information. I got it.
I'm thinking of using the priority-based sheduling on a
dedicated embedded controller on the control network.
So, running EPICS as root should be OK.
(Acutually, we have already been running EPICS as root on
the controller...)
I surely look into epicsTreadPriorityTest to see how it
works.
Thank you again for your help.
Jun-ichi
----- Original Message -----
> Hi Jun-ichi,
> On Wednesday 22 April 2009 07:47:51 [email protected] wrote:
> > Thank you very much for the information.
> > Just say "YES"...
> > Is that all what I have to do?
> Well, almost.  Linux only allows processes to use the pthreads real-
time
> priorities if the process is sufficiently privileged (because it's
easy to
> code a Denial of Service attack to bring down the OS if you have that
> privilege).  There's probably a Capability (CAP_xx) that controls this,
 but I
> don't know what it is.  The easiest way to provide that is to run the
IOC as
> root, which I don't recommend on a general-use system for security
reasons
> but should be Ok on a dedicated machine.
> There is a test program called epicsThreadPriorityTest that you can
run from
> your base/src/libCom/test/O.<arch> directory which tells you whether
the
> threads are being scheduled strictly by priority or not, so you should
be
> able to use that to experiment.
> HTH,
> - Andrew
> > > > Dear All;
> > > > I've recently come to notice that the real-time performance of
Linux
> > > > kernel is incredibly improving (against my expectations).
> > > > http://www.osadl.org/Single-View.111+M5b96e97f67b.0.html
> > > > I'd like to know if the implementation of OSD-library is
implemented
> > in
> > > > such a manner that the kernel-level threads can reflect the
priority
> > > > given by the user to the scheduling of epicsThreads?
> > > > In other words, can I benefit from the improvement of Linux
kernel
> > > > without making any changes in EPICS source codes?
> > > in file base/configure/CONFIG_SITE
> > > change
> > > USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO
> > > to
> > > USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
> > > Also you must start the IOC as root.
> > > Marty
> The best FOSS code is written to be read by other humans -- Harold
Welte
Priorities of epicsThreads on Linux jun-ichi.odagiri
Re: Priorities of epicsThreads on Linux Marty Kraimer
Re: Priorities of epicsThreads on Linux jun-ichi.odagiri
Re: Priorities of epicsThreads on Linux Andrew Johnson
Prev: Re: back propagating error states Andrew Johnson
Next: XIA xMAP software Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Priorities of epicsThreads on Linux Andrew Johnson
Next: VisualDCT 2.6.1742 release Matej Sekoranja
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
