1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor Record OMSL field
To: EPICS <[email protected]>
Date: Thu, 04 Jun 2009 12:21:46 -0500
Hello EPICS motor record users,
Has anyone used (or is currently using) the motor record with the
OMSL field  set to "closed-loop"?
If not, I plan on removing it from the motor record with the next
"major" release (i.e. R6-5).
Here at the APS, we use save/restore to preserve the motor record's
DVAL through a reboot or power-cycle.  Setting the OMSL to
"closed-loop" has the undesirable effect of  preserving DVAL,
but leaving the VAL and RVAL fields to their default values; zero.
Since incremental moves (tweaks) are done from user coordinates
(i.e. the VAL field), an incremental move after a reboot would
cause the motor to move, unexpectedly, to near the zero position.
Since I am unaware of any use for the OMSL field to be set to
"closed-loop", I strongly recommend that motor record users leave
this field in its' default "supervisory" state.
Ron
Re: Motor Record OMSL field Ron Sluiter
Prev: Re: subArray processing Carl Lionberger
Next: EDM Properties Windows Aaron Joos
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: catools for cross compiled target Hinko Kocevar
Next: Re: Motor Record OMSL field Ron Sluiter
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
