1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray processing
To: [email protected]
Date: Thu, 04 Jun 2009 09:59:17 -0700
Hi Hinko,
From a quick look at the camonitor code it seems to be using a low-level element count derived from channel access activity for its printout. For a generic client of this sort such an approach is reasonable.
I think you should use MALM of 2. This should work and would reduce the trailing zero count
Carl
Hinko Kocevar wrote:
I'm testing the outputs with the camonitor utility supplied with the
EPICS base.
Hinko
Carl Lionberger
Control System Software Engineer
Berkeley National Laboratory (LBNL)
(510) 486-7503
Re: subArray processing Hinko Kocevar
Re: subArray processing Carl Lionberger
Prev: Re: Converting DEC to HEX Tim Mooney
Next: Motor Record OMSL field Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray processing Hinko Kocevar
Next: Re: subArray processing Hinko Kocevar
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
