1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray processing
To: [email protected]
Cc: [email protected]
Date: Fri, 05 Jun 2009 11:27:34 +0200
Carl Lionberger wrote:
> Hi Hinko,
> From a quick look at the camonitor code it seems to be using a low-level
> element count derived from channel access activity for its printout. For
> a generic client of this sort such an approach is reasonable.
> I think you should use MALM of 2.  This should work and would reduce the
> trailing zero count
Ok, this works as you pointed out, the number of trailing zeros is
reduced to 1.
I'm not sure what our end users will use instead of camonitor and how it
handles the subArray..
Thank you,
Hinko
Hinko Kocevar
Technical support engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
subArray processing Hinko Kocevar
Re: subArray processing Carl Lionberger
Re: subArray processing Hinko Kocevar
Prev: Plotting array of data in striptool Prachi Chitnis
Next: Re: catools for cross compiled target Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray processing Carl Lionberger
Next: LabView shared memory interface Kevin Tsubota
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
