1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Converting DEC to HEX
To: Prachi Chitnis <[email protected]>
Cc: [email protected], [email protected], [email protected], [email protected]
Date: Thu, 04 Jun 2009 11:05:11 -0500
If you already have the scalcout record type, you can use the calc
expression
	PRINT("%x", a)
where the .A field holds your decimal number.
Prachi Chitnis wrote:
Hello,
Is there any way to convert the DEC value to HEX value in IOC database? I
am able to convert HEX to DEC by prepending "0x" before the HEX string and
ai record understands it as DEC. But I am unable to convert it back to
HEX. I however found another method for DEC to HEX conversion, converting
DEC to BIN (mbbiDirect), separating them to nibbles and getting DEC value
of the nibble (mbboDirect), then it is converted to HEX char by string
fields of mbbi record, and adding the HEX characters together by scalcout.
But this is increasing the processing time as many fanout records are
involved in between.
Please suggest some method.
Thanks and regards,
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Converting DEC to HEX Prachi Chitnis
Prev: Re: catools for cross compiled target Janet Anderson
Next: Re: subArray processing Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Converting DEC to HEX Prachi Chitnis
Next: catools for cross compiled target Hinko Kocevar
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
