1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing Protocol Files
To: Eric Bjorklund <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 15 Jun 2009 15:18:56 -0500
Eric,
In our local copy of streams, we've added a 'protocols' directory, but I don't think anyone's ever used it. I think most people put protocol files in the same directory as the first database that used them.
You can set the STREAM_PROTOCOL_PATH to anything in your cdCommands or envPaths
file with, for example:
epicsEnvSet("STREAM_PROTOCOL_PATH","$(TOP)")
If this doesn't get you to the required directory, you could supplement with a fixed path from there:
epicsEnvSet("STREAM_PROTOCOL_PATH","$(TOP)/abc/def")
Tim
Eric Bjorklund wrote:
Hello,
We are just getting started with StreamDevice and were curious to know where other sites put their protocol files so that they can be referenced by the IOCs that want them. Do you "install" them from shared apps (like DBD's or scripts)? Is there an easy (or automatic) way to set the STREAM_PROTOCOL_PATH environment variable based on the definitions in the configure/RELEASE file? What is the current state of the art in protocol file maintenance?
Thanks in advance,
-Eric Bj.
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031 email: [email protected] <mailto:[email protected]>
"The universe is full of magical things,
patiently waiting for our wits to grow sharper"
-- Eden Phillpotts Correspondence
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
Installing Protocol Files Eric Bjorklund
Prev: Re: help for developing a simple application on EPICS Pete Jemian
Next: RE: problem about environment variables under vxWorks-6.6 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Installing Protocol Files Eric Bjorklund
Next: Re: Installing Protocol Files Dirk Zimoch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
