1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing Protocol Files
To: Eric Bjorklund <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 16 Jun 2009 14:34:29 +0200
Hi Eric,
At PSI, we install then into a cfg/ subdirectory for each IOC.
When I was at DELTA, we installed them into a common protocols/ directory.
It a philosophical question, not a technical one. I would say wherever you install templates (ioc boot directory or global pool) do the same with the protocol files.
You can even do both, first look locally then in the pool. STREAM_PROTOCOL_PATH accepts a list of directories (like PATH).
Dirk
Eric Bjorklund wrote:
Hello,
We are just getting started with StreamDevice and were curious to know where other sites put their protocol files so that they can be referenced by the IOCs that want them. Do you "install" them from shared apps (like DBD's or scripts)? Is there an easy (or automatic) way to set the STREAM_PROTOCOL_PATH environment variable based on the definitions in the configure/RELEASE file? What is the current state of the art in protocol file maintenance?
Thanks in advance,
-Eric Bj.
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031 email: [email protected] <mailto:[email protected]>
"The universe is full of magical things,
patiently waiting for our wits to grow sharper"
-- Eden Phillpotts Correspondence
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Installing Protocol Files Eric Bjorklund
Prev: Re: "A32 RegisterAddress error" about Hytec8401 Michael Abbott
Next: Re: "A32 RegisterAddress error" about Hytec8401 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing Protocol Files Tim Mooney
Next: "A32 RegisterAddress error" about Hytec8401 liuping
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
