1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "A32 RegisterAddress error" about Hytec8401
Cc: Michael Abbott <[email protected]>, [email protected]
Date: Thu, 18 Jun 2009 10:59:30 +0200
Andrew Johnson wrote:
Hi Liu Ping,
Read the target.txt file in your target/config/<bsp> directory, it should document the window mappings. Look for the VME_A32_MSTR_BUS and VME_A32_MSTR_SIZE variables; you may be able to just modify them and rebuild the BSP, but don't just make the window as large as possible because that can significantly slow down the startup of the vxWorks image at boot time and also use up memory in MMU page tables.
If you are using a PPC cpu, then there are other ways to map 1GB of A32 space without slowing down vxWorks or using MMU tables. If you are interested ask me.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
"A32 RegisterAddress error" about Hytec8401 liuping
Re: "A32 RegisterAddress error" about Hytec8401 Michael Abbott
Re: "A32 RegisterAddress error" about Hytec8401 Andrew Johnson
Prev: Re: Pfeiffer Turbo Pump /controller J. Lewis Muir
Next: Re: Pfeiffer Turbo Pump /controller Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "A32 RegisterAddress error" about Hytec8401 Andrew Johnson
Next: re: "A32 RegisterAddress error" about Hytec8401 liuping
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
