1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pfeiffer Turbo Pump /controller
To: Vesna Samardzic-Boban <[email protected]>
Date: Thu, 18 Jun 2009 13:50:21 +0200
Hi Vesna,
We are using the Pfeiffer Maxi Gauge with RS485 interface (via USB). See the attached files. You need StreamDevice and Aysn.
Here is a startup script snippet:
drvAsynSerialPortConfigure MaxiGauge1 /dev/ttyUSB0
asynSetOption MaxiGauge1, 0, "baud", "19200")
asynSetOption MaxiGauge1, 0, "bits", "8")
asynSetOption MaxiGauge1, 0, "parity", "none")
asynSetOption MaxiGauge1, 0, "stop", "1")
asynSetOption MaxiGauge1, 0, "clocal", "Y")
asynSetOption MaxiGauge1, 0, "crtscts", "N")
Dirk
Vesna Samardzic-Boban wrote:
Hi All,
Has anyone interfaced to EPICS via serial interface Pfeiffer Turbo-Molecular Pump station?
Our set is comprised of:
Turbomolecular pump TMH 071 P integrated with TC 100 electronic drive,
Display Control Unit DCU 100 and
Connection box TC 010.
Or any other controller from Pfeiffer  to EPICS.
Thanks and regards
Vesna
Vesna Samardzic-Boban | Controls Engineer | Australian Synchrotron
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
InTerminator = CR LF;
replytimeout = 10000;
readtimeout = 1000;
#address = "";         # for RS232
address = ESC "0\$1"; # for RS485
@mismatch { out ETX; }
debug {
    out $address "%s" CR;
    in ACK;
    out ENQ;
    in "%39c";
pressure {
    out $address "PR\$2" CR;
    in ACK;
    out ENQ;
    in "%(\$3:STATUS.VAL)d,%f";
record (stringout, "$(DEVICE):DEBUG")
    field (DTYP, "stream")
    field (OUT,  "@MaxiGauge.proto debug($(ADDR)) $(BUS)")
record (ai, "$(NAME):READ")
    field (INP,  "@MaxiGauge.proto pressure($(ADDR),$(SENSOR),$(NAME)) $(BUS)")
    field (EGU,  "mbar")
    field (PREC, "-3")
    field (SCAN, "1 second")
    field (FLNK, "$(NAME):PRESSURE")
record (mbbi, "$(NAME):STATUS")
    field (ZRST, "OK")
    field (ONST, "UNDERRANGE")
    field (TWST, "OVERRANGE")
    field (THST, "SENSOR ERROR")
    field (FRST, "SENSOR OFF")
    field (FVST, "NO SENSOR")
    field (SXST, "ID ERROR")
    field (SVST, "NO DEVICE")
    field (ONSV, "MINOR")
    field (TWSV, "MAJOR")
    field (THSV, "INVALID")
    field (FRSV, "INVALID")
    field (FVSV, "INVALID")
    field (SXSV, "INVALID")
    field (SVSV, "INVALID")
record (calcout, "$(NAME):DISCONNECTED")
    field (INPA, "$(NAME):READ.STAT CP")
    field (CALC, "A=10")
    field (OOPT, "Transition To Non-zero")
    field (DOPT, "Use OCAL")
    field (OCAL, "7")
    field (OUT,  "$(NAME):STATUS PP")
record (calc, "$(NAME):PRESSURE")
    field (INPA, "$(NAME):READ MS")
    field (INPB, "$(NAME):STATUS MS")
    field (CALC, "A")
    field (EGU,  "mbar")
    field (PREC, "-3")
file MaxiGauge.template
{ pattern
 { DEVICE   BUS        ADDR }
 { DZ-MAXI1 MaxiGauge1  0   }
# { DZ-MAXI2 MaxiGauge1  1   }
file MaxiGaugeSensor.template
{ pattern
 { NAME     BUS        ADDR SENSOR }
 { DZ-VAC1  MaxiGauge1  0      1   }
 { DZ-VAC2  MaxiGauge1  0      2   }
 { DZ-VAC3  MaxiGauge1  0      3   }
 { DZ-VAC4  MaxiGauge1  0      4   }
 { DZ-VAC5  MaxiGauge1  0      5   }
 { DZ-VAC6  MaxiGauge1  0      6   }
# { DZ-VAC7  MaxiGauge1  1      1   }
# { DZ-VAC8  MaxiGauge1  1      2   }
# { DZ-VAC9  MaxiGauge1  1      3   }
# { DZ-VAC10  MaxiGauge1  1      4   }
# { DZ-VAC11  MaxiGauge1  1      5   }
# { DZ-VAC12  MaxiGauge1  1      6   }
Pfeiffer Turbo Pump /controller Vesna Samardzic-Boban
Prev: Re: "A32 RegisterAddress error" about Hytec8401 Dirk Zimoch
Next: A problem about edm 闫芬
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Pfeiffer Turbo Pump /controller J. Lewis Muir
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
