1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Vxi11
To: "Szalata, Zenon M." <[email protected]>, <[email protected]>
Date: Thu, 23 Jul 2009 16:06:03 -0500
One suggestion would be to set asynTraceIOMask=2 and traceIOMask=255 for
that asynPort in your startup script.  Then reboot the IOC until it
fails and see if you can what is different in the traffic.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Thursday, July 23, 2009 4:03 PM
To: [email protected]
Subject: Vxi11
I am using ICS 8065 Ethernet - GPIB gateway.  The soft IOC is built with
EPICS R3.14.9, asyn version 4.11, streamdevice version 2.4.  Sometime
when I restart the IOC it dies with the following error:
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Mar  2 2009
2009/07/23 13:28:10.304 L0 vxiCreateIrqChannel VXI: channel not
established (create_intr_chan)
2009/07/23 13:28:10.304 L0 Warning -- SRQ not operational.
@@@ Received a sigChild for process 29220. The process was killed by
signal 11
@@@ Current time: Thu Jul 23 13:28:10 2009
I don't understand these error messages.  I need to understand in what
way the gateway is failing so that I can explain my problem more
intelligently to the tech support at ICS.  So, my question is how to
interpret the messages listed above?
Are there other users of the ICS 8065 gateway?  Has anyone seen this
problem? If so what is the solution?
Zen
RE: Vxi11 Szalata, Zenon M.
Prev: Vxi11 Szalata, Zenon M.
Next: RE: Vxi11 Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
