1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Vxi11
To: <[email protected]>
Date: Thu, 23 Jul 2009 14:02:53 -0700
I am using ICS 8065 Ethernet - GPIB gateway.  The soft IOC is built with EPICS R3.14.9, asyn version 4.11, streamdevice version 2.4.  Sometime when I restart the IOC it dies with the following error:
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Mar  2 2009
2009/07/23 13:28:10.304 L0 vxiCreateIrqChannel VXI: channel not established (create_intr_chan)
2009/07/23 13:28:10.304 L0 Warning -- SRQ not operational.
@@@ Received a sigChild for process 29220. The process was killed by signal 11
@@@ Current time: Thu Jul 23 13:28:10 2009
I don't understand these error messages.  I need to understand in what way the gateway is failing so that I can explain my problem more intelligently to the tech support at ICS.  So, my question is how to interpret the messages listed above?
Are there other users of the ICS 8065 gateway?  Has anyone seen this problem? If so what is the solution?
Zen
RE: Vxi11 Mark Rivers
Prev: Re: Waveform record updating problem Eric Norum
Next: RE: Vxi11 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform record updating problem Prachi Chitnis
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
