1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform record updating problem
To: [email protected]
Cc: [email protected], [email protected], [email protected]
Date: Fri, 24 Jul 2009 11:45:50 +0530 (IST)
Hello,
By saying  "I could not use Asyn to communicate with this scope" I meant
that I could not use Asyn directly. This scope uses the VICP protocol.
I had a C driver for this scope, so it was easier to develop the device
support. Because I am a newbie to EPICS, I was avoiding Asyn to be used
with this scope, when I had a ready-to-use driver.
I am using Asyn with many other devices, and it works great.
I regret if my statement looked like as if I am doubtful about Asyn :)
Looking forward to hear from you on updating problem. Developing asyn port
driver is another good option I see.
Thanks n regards,
Prachi Chitnis
Scientific Officer C
Accelerator Control Section
RRCAT, Indore, India
> Hello,
> My setup consists of a LeCroy scope that is interfaced to an Ubuntu 8.10
machine on Ethernet.
> I could not use Asyn to communicate with this scope, so I wrote device
support for it. My db file is as follows:
> record(waveform, GetWFC1) {
>   field(SCAN, "1 second")
>   field(PINI, "NO")
>   field(DTYP, "LeCroy WaveSurfer")
>   field(INP, "#C1 S1 @C1:WAVEFORM? DAT1\n")
>   field(NELM, "1000")
>   field(FTVL, "CHAR")
> record(waveform, C1a) {
>   field(PINI, "NO")
>   field(DTYP, "Soft Channel")
>   field(INP, "GetWFC1 CA")
>   field(NELM, "1000")
>   field(FTVL, "CHAR")
> I am using the VME_IO for input link for "LeCroy Wavesurfer" device
support. Card = (1,0) denotes (write, no write) to device, Signal =
(1,0)
> denotes (read, no read) from the device and the parm denotes the command
to be written to the device. The GetWFC1.VAL field is showing correct
data
> & is updating properly.
> My problems are:
> 1)  When I keep C1a.INP as PP, I dont get any data into it.
> 2)  When I keep C1a.INP as CA (also CP), and monitor this record, I get
the data into VAL field, the timestamp updates but the data doesn't
update.
> 3)  When I morph C1a to subarray record, with same fields and MALM set
to
> 1000, the the same prob as 2) occurs
> 4) I also set the PHAS fields of both records as 0 and 1(resp.), but
that
> too didn't work.
> 5)  When I group these two records, then nor PP neither CA input link is
able to fetch data into the VAL field of group:C1a record.
> 6)  I also tried to make the scan rate of C1a faster than GetWFC1, but
that didn't help.
> Please suggest some solution.
> Thanx in advance...
> Prachi Chitnis
> Scientific Officer 'C'
> Raja Ramanna Centre for Advanced Technology, Indore
> India
Prev: Re: Vxi11 Eric Norum
Next: Re: --more-- Waveform record updating problem Prachi Chitnis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Waveform record updating problem Eric Norum
Next: Vxi11 Szalata, Zenon M.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
