1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Linux question
To: <[email protected]>
Date: Thu, 6 Aug 2009 07:55:03 -0500
Folks,
This is not exactly an EPICS-specific question, but I'm having trouble running EPICS binaries built on one recent Linux system on another recent Linux system.  It just gives a "command not found" error, which is not very helpful.  Both systems are Fedora 64-bit; the binary is built with HOST_ARCH=linux-x86, e.g. 32-bit.
Here is an example.  I am trying to run a soft IOC in the current directly.  First I run "file" and "ldd" on it, then try to run it:
[epics@localhost linux-x86]$ file ./simDetectorApp
./simDetectorApp: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.9, not stripped
[epics@localhost linux-x86]$ ldd ./simDetectorApp
        not a dynamic executable
[epics@localhost linux-x86]$ ./simDetectorApp
./simDetectorApp: Command not found.
Note that ldd says this is not a dynamic executable, which is incorrect.
Here is the version information on the system where the binary was built and where the executable resides:
corvette:1-5beta/ADApp/simDetectorSrc>more /proc/version
Linux version 2.6.27.21-78.2.41.fc9.i686 (mockbuild@) (gcc version 4.3.0 20080428 (Red Hat 4.3.0-8) (GCC) ) #1 SMP Mon Mar 23 23:45:58 EDT 2009
Here is the version information on the system that will not run the binary:
[epics@localhost linux-x86]$ more /proc/version
Linux version 2.6.27.25-170.2.72.fc10.x86_64 ([email protected]) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Sun Jun 21 18:39:34 EDT 2009
If I run "file" and "ldd" on the file on the system that builds it and runs it OK I get the following:
corvette:1-5beta/bin/linux-x86>file simDetectorApp
corvette:1-5beta/bin/linux-x86>ldd simDetectorApp
        linux-gate.so.1 =>  (0x0035b000)
        libpthread.so.0 => /lib/libpthread.so.0 (0x003b3000)
        libreadline.so.5 => /lib/libreadline.so.5 (0x05ac2000)
        libncurses.so.5 => /lib/libncurses.so.5 (0x05f3b000)
        librt.so.1 => /lib/librt.so.1 (0x004c8000)
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x066c5000)
        libm.so.6 => /lib/libm.so.6 (0x00363000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x066b5000)
        libc.so.6 => /lib/libc.so.6 (0x004d2000)
        /lib/ld-linux.so.2 (0x001d8000)
        libtinfo.so.5 => /lib/libtinfo.so.5 (0x05c57000)
        libdl.so.2 => /lib/libdl.so.2 (0x0038e000)
corvette:1-5beta/bin/linux-x86>./simDetectorApp
Any idea what could be wrong?
Re: Linux question ZY (Zhijian Yin)
RE: Linux question Ernest L. Williams
Prev: RE: CA reconnection problem Rees, NP (Nick)
Next: Re: Linux question ZY (Zhijian Yin)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EDM and MEDM panels for ZTEC's EPICS oscilloscopes Boyd Shaw
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
