1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem using epid record
To: Pal Trivan <[email protected]>
Cc: [email protected]
Date: Wed, 26 Aug 2009 12:35:12 +0200
First of all thank for your info, i read something about the "SynApps"
package and it is very interesting.
I have a question: if i want use only the epid record with your
package, how do i have to set the makefile?
thank a lot!
Maurizio M.
2009/8/26, Pal Trivan <[email protected]>:
> Hi,
> I'm also a user of the epid record (which by the way is *great*). However, I
> use it here at PSI within our 'custom' environment.
> In the Epics release R3.14.8.2 it is located in the 'SynApps' package, which
> you should include.
> I would be happy to share any other information on the usage (from my
> experience), if you would like.
> Regards,
> Trivan
> Dr. Trivan Pal
> [email protected]
> +41 56 310 4558
> PSI
> Switzerland
> ________________________________
> From: [email protected] on behalf of Maurizio Montis
> Sent: Wed 8/26/2009 11:22 AM
> To: [email protected]
> Subject: problem using epid record
> Hi,
> i'm looking for to use the epid record to control an High Voltage
> Power Supply but i'm in trouble: i'm trying to compile my ioc but i
> have this kind of error:
> make[3]: *** No rule to make target
> `../../../lib/linux-x86//libepidRecord.a', needed by `testPID'.  Stop.
> I've setted the Makefile in src directory specifing:
> 1) testPID_DBD += epidRecord.dbd
> 2) testPID_LIBS += epidRecord
> 3) testPID_LIBS += devEpidSoft
> where is my mastake? thanks a lot for any suggestions.
> Maurizio M.
RE: problem using epid record Mark Rivers
problem using epid record Maurizio Montis
RE: problem using epid record Pal Trivan
Prev: RE: problem using epid record Pal Trivan
Next: Re: problem using epid record Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: problem using epid record Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
