1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: problem using epid record
To: Maurizio Montis <[email protected]>
Cc: [email protected]
Date: Wed, 26 Aug 2009 06:58:39 -0400
Ciao Maurizio,
you are probably missing the appropriate configuration in the .../configure/RELEASE file of your working tree, which has the information about all external modules needed. In that file, you should have an entry like
 EPID=<location of the epid package>
To make things work, you will have to run make in the top level directory of your working tree (or in .../configure directory itself) before trying to recompile your IOC library.
Hope this helps,
Ralph
On 26.08.2009 05:22 Maurizio Montis wrote:
i'm looking for to use the epid record to control an High Voltage
Power Supply but i'm in trouble: i'm trying to compile my ioc but i
have this kind of error:
make[3]: *** No rule to make target
`../../../lib/linux-x86//libepidRecord.a', needed by `testPID'.  Stop.
I've setted the Makefile in src directory specifing:
1) testPID_DBD += epidRecord.dbd
2) testPID_LIBS += epidRecord
3) testPID_LIBS += devEpidSoft
where is my mastake? thanks a lot for any suggestions.
Maurizio M.
problem using epid record Maurizio Montis
Prev: Re: problem using epid record Maurizio Montis
Next: RE: problem using epid record Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: problem using epid record Mark Rivers
Next: Re: problem using epid record Ralph Lange
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
