1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Events
To: Csaba Gajo <[email protected]>, [email protected]
Date: Fri, 4 Sep 2009 10:28:34 -0500 (CDT)
To issue a soft event, you will have to use the calcout record.  I don't remember what the field is called, but its there.
   Ned
>Hello,
>I was reading the documentation about events, and was trying to make a
>simple program to see how it works. In it I have a calc record, which
>increments itself by 1 each second. When the values is 10, it raises a
>HIHI signal.
>I also have another calc record, whose SCAN field is Event, and it's
>supposed to react when the value of the first calc reaches 10.
>In the documentation, I was reading that when a user-defined event is
>thrown, "all records will be processed whose SCAN field specifies
>event and whose event number is the same as the generated event". So,
>obviously HIHI is not a user-defined event. How should I throw an
>event when the value of calc1 reaches 10?
>Regards, Csaba
Prev: Re: Events Paul Sichta
Next: Re: Events Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Events Dalesio, Leo
Next: asyn compiler problems Pierrick Hanlet
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
