1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn compiler problems
Date: Tue, 08 Sep 2009 08:30:50 -0500
n attempting to build the asyn support package, v4.12, and even v4.11, I cannot even compile the
package.  Initially, I found some spurious characters in the dbd file.  I'm now stumped (and have
been since 08:00 today) with the compilation error message.
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/os/Linux -I../../include   -I/home/epics/epics/base/include/os/Linux -I/home/epics/epics/base/include        ../../asyn/asynRecord/asynRecord.c
../../asyn/asynRecord/asynRecord.c: In function ‘init_record’:
../../asyn/asynRecord/asynRecord.c:264: error: ‘asynRecord’ has no member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:272: error: ‘asynRecord’ has no member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:285: error: ‘asynRecord’ has no member named ‘udf’
../../asyn/asynRecord/asynRecord.c:296: error: ‘asynRecord’ has no member named ‘name’
These members are defined in a number of /home/epics/epics/base/include files of different
record types.  Can (will) you kindly assist me?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Re: asyn compiler problems Eric Norum
Re: asyn compiler problems Emmanuel Mayssat
Prev: RE: Events Dalesio, Leo
Next: TR: Access security problem GOURNAY Jean-Francois
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Events nda
Next: Re: asyn compiler problems Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
