1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TR: Access security problem
To: <[email protected]>
Date: Tue, 8 Sep 2009 15:51:50 +0200
This message sent yesterday didn’t show up.
Hello
I try the following ASG configuration file:
UAG(tous) {spiral2, spiral2mgr, gournay}
UAG(physique) {spiral2}
UAG(develop) {spiral2mgr}
UAG(gournay) {gournay}
HAG(hag) {dappck110}
ASG(DEFAULT) {
      INPA(ASGVAL)
      RULE(1,READ)
      RULE(1,WRITE) {
            UAG(tous)
            HAG(hag)
            CALC("A&1=1")
      RULE(1,WRITE) {
            UAG(develop)
            HAG(hag)
            CALC("A>>1=1")
      RULE(1,WRITE) {
            UAG(physique)
            HAG(hag)
            CALC("A>>2=1")
      RULE(1,WRITE) {
            UAG(gournay)
            HAG(hag)
            CALC("A>>3=1")
The idea is to change WRITE permission depending on the value of a longout record ASGVAL (ASGVAL.VAL = 1,2,4,8)
It doesn’t work: for A=1 the 3 users defined in “tous”  have WRITE access whatever UAG. For A != 1 no WRITE access at all. As I am in ASG DEFAULT, I did’nt specify anything for the ASG Fields in the database.
What is wrong in this scheme?
Another point: I did’nt really understand the meaning of RULE(1 … vs RULE(0 …
Thanks!
J.F. Gournay
CEA Saclay
IRFU/SIS
Re: TR: Access security problem Martin L. Smith
RE: Access security problem GOURNAY Jean-Francois
Prev: asyn compiler problems Pierrick Hanlet
Next: Re: asyn compiler problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RE: asyn compiler problems Pierrick Hanlet
Next: Re: TR: Access security problem Martin L. Smith
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
