1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: asyn compiler problems
Cc: [email protected]
Date: Tue, 08 Sep 2009 15:40:48 -0500
Thanks for the help; there was a problem with file corruption.  I deleted the tarball, reloaded,
reextracted, and rebuilt.  All is well.
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Tuesday, September 8, 2009 3:35 pm
Subject: RE: asyn compiler problems
To: Emmanuel Mayssat <[email protected]>, Pierrick Hanlet <[email protected]>
> I don't think the problem is that it cannot find base, at least not at
> compile time.  If that were the case I would expect to see many error
> messages about not being able to find epicsMutex.h, etc.
> I concur with Eric, I think something was corrupted with your download
> or tar file extraction.
> I normally build asyn from a CVS checkout, but just to be sure that
> there was nothing wrong with the tar.gz file on the asyn Web site, I
> just downloaded and built asyn from that file on Linux and vxWorks.
> It built fine, there is nothing wrong with the asynRecord.dbd file.
> Mark
> ________________________________
> From: [email protected] on behalf of Emmanuel Mayssat
> Sent: Tue 9/8/2009 2:54 PM
> To: Pierrick Hanlet
> Subject: Re: asyn compiler problems
> Pierrick Hanlet wrote:
> > Hi,
> > n attempting to build the asyn support package, v4.12, and even
> v4.11, I cannot even compile the
> > package.  Initially, I found some spurious characters in the dbd
> file.  I'm now stumped (and have
> > been since 08:00 today) with the compilation error message.
> > /usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
> -D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I.
> -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib
> -I../../asyn/drvAsynSerial -I../../asyn/interfaces
> -I../../asyn/miscellaneous -I../../asyn/devEpics
> -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014
> -I../../asyn/devGpib -I../../include/os/Linux -I../../include
> -I/home/epics/epics/base/include/os/Linux
> -I/home/epics/epics/base/include        ../../asyn/asynRecord/asynRecord.c
> > ../../asyn/asynRecord/asynRecord.c: In function 'init_record':
> > ../../asyn/asynRecord/asynRecord.c:264: error: 'asynRecord' has no
> member named 'dpvt'
> > ../../asyn/asynRecord/asynRecord.c:272: error: 'asynRecord' has no
> member named 'dpvt'
> > ../../asyn/asynRecord/asynRecord.c:285: error: 'asynRecord' has no
> member named 'udf'
> > ../../asyn/asynRecord/asynRecord.c:296: error: 'asynRecord' has no
> member named 'name'
> It seems asyn cannot find dbCommon.dbd where all those fields are declared.
> dbCommon is located in the epics base. So check where your
> config/configure files are pointing to. (did you 'make' the base?)
> > These members are defined in a number of
> /home/epics/epics/base/include files of different
> > record types.  Can (will) you kindly assist me?
> > Thanks,
> > Pierrick
> > Pierrick Hanlet
> > Batavia, IL 60510
> > [email protected]
asyn compiler problems Pierrick Hanlet
Re: asyn compiler problems Emmanuel Mayssat
RE: asyn compiler problems Mark Rivers
Prev: RE: asyn compiler problems Mark Rivers
Next: RE: sequencer feature request Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: TR: Access security problem GOURNAY Jean-Francois
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
