1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access security problem
To: [email protected]
Cc: GOURNAY Jean-Francois <[email protected]>
Date: Wed, 9 Sep 2009 09:56:17 -0500
On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
> I did more systematic tests and I have this strange situation:
> ASGVAL  UAG      spiral2  spiral2mgr      gournay
> 1       tous      W        W               W        OK
> 2       develop   -        - (should be W) -        WRONG
> 4       physique  W        -               -        OK
> 8       gournay   -        W (should be -) W        WRONG
> W : database WRITE access
> - :  no write access
> I modified the CALC expressions accordingly to Martin suggestion :
> CALC("A&1") instead of CALC("A&1=1").  But I don't think I have to write
> CALC (A>0&&A<2) as my A value comes from a longout record.
You're right there, but for historical reasons the relative precedence of
the ">>" and "=" operators are different in C and CALC, so you do need to
change your expressions:
>             CALC("A&1=1")
As Marty suggested "A&1" is sufficient here
>             CALC("A>>1=1")
CALC actually evaluates this as "A>>(1=1)" which is not what you mean.  You
could use "(A>>1)=1" but I would suggest "A&2" here instead.
>             CALC("A>>2=1")
"A&4"
>             CALC("A>>3=1")
"A&8"
Using fewer operators will also parse and execute faster.
> This message sent yesterday didn't show up.
That's because you actually sent it to tech-talk-bounces@aps., not to
tech-talk@aps., and I didn't get a chance to forward it manually before you
re-sent it.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Access security problem GOURNAY Jean-Francois
TR: Access security problem GOURNAY Jean-Francois
Prev: Re: sequencer feature request Eric Norum
Next: 2eSST??? Eric Bjorklund
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Access security problem GOURNAY Jean-Francois
Next: RE: Access security problem GOURNAY Jean-Francois
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
