1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 2eSST???
To: "Eric Bjorklund" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 10 Sep 2009 00:24:27 +0200
Hi Eric,
1. Yes, I have recently done quite some work on this issue (hopefully I will talk about it in EPICS meeting).
2. The bandwidth you get depends on the hardware of course. I tried it on a SIS3302 ADC from Struck with mvme-6100 and mvme-4100 SBC’s (vxWorks OS). In the best case I could get like 85 MB/s. The guys in Struck told me that the highest rate they have measured is about 90 MB/s but they use a special self-developed PCI/cPCI-VME interface card to read the data.
3. Yes, mvme-6100 and mvme-3100 BSP’s have a usable driver (much better than mvme-5100 / 2300) but you have still to do some work. First issue is that you have to set the right transfer protocol for the VME (outbound) window in use. If you always use the same protocol (very unlikely!) you can hard code this only once in the BSP but if you have boards with different protocols e.g. MBLT, 2eVME, etc. then you have to be able to set the protocol of the corresponding window dynamically at runtime. Second issue is that the API provided with the out-of-the-box BSP is single-requester; meaning that while one DMA transfer is executing the second transfer request is not accepted. Therefore the application program has to keep retrying until his request gets accepted (at some time when DMA engine is not busy).
I have written a (BSP) driver on top of the existing routines which addresses above mentioned problems. We also use the same API for all our SBC’s (mevme-6100, 4100, 5100, 2300 series) to ease writing and maintaining our drivers/application programs.
Babak
PS: you may get a little bit better rates by disabling the caching/snooping in the BSP but you have to then take care of data consistency too.
From: [email protected] [mailto:[email protected]] On Behalf Of Eric Bjorklund
Sent: Mittwoch, 9. September 2009 18:36
To: EPICS tech-talk
Subject: 2eSST???
This is another one of those "help me not re-invent the wheel" surveys...
1. Is anyone currently using 2eSST DMA ?
2. If so, what kind of bandwidth are you getting, and,
3. Did you have to do anything special to get it to work?  (e.g. BSP mods, etc.)
Thanks in advance,
-Eric Bj.
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031                                                     email:  [email protected]
"The universe is full of magical things,
patiently waiting for our wits to grow sharper"
 -- Eden Phillpotts        Correspondence
2eSST??? Eric Bjorklund
Prev: RE: sequencer feature request Chestnut, Ronald P.
Next: Re: sequencer feature request Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 2eSST??? Eric Bjorklund
Next: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
