1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: sequencer feature request
To: <[email protected]>
Date: Wed, 9 Sep 2009 10:54:26 -0700
Mr. Expedient here.
With any luck, all the code in the sequencer uses MACRO_STR_LEN, and a change to something larger but static (perhaps 61 or 100?) might just work after a recompile. Doing something dynamic requires actual thinking and more extensive testing. How about an initial static bump with a subsequent dynamic solution?
Ron Chestnut
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Eric Norum
Sent: Wednesday, September 09, 2009 6:15 AM
To: [email protected] Techtalk
Subject: Re: sequencer feature request
Mr. Small IOC here.
Rather than allocating the maximum-sized space for every single name,
why not expand the name into a 'big-enough' buffer and then allocate
only the required size and copy the result?
On Sep 9, 2009, at 5:13 AM, Dirk Zimoch wrote:
> I found several places in the code where the sequencer uses
> MAX_STRING_SIZE+1 for string lengths of PV names and macros. In
> EPICS base MAX_STRING_SIZE is defined as 40. For example in
> seq_main.c:
> * Evaluate channel names by macro substitution.
> #define		MACRO_STR_LEN	(MAX_STRING_SIZE+1)
> LOCAL void seqChanNameEval(pSP)
> SPROG		*pSP;
> 	CHAN		*pDB;
> 	int		i;
> 	pDB = pSP->pChan;
> 	for (i = 0; i < pSP->numChans; i++, pDB++)
> 		pDB->dbName = calloc(1, MACRO_STR_LEN);
> 		seqMacEval(pDB->dbAsName, pDB->dbName, MACRO_STR_LEN, pSP->pMacros);
> #ifdef	DEBUG
> 		printf("seqChanNameEval: \"%s\" evaluated to \"%s\"\n",
> 			pDB->dbAsName, pDB->dbName);
> #endif	/*DEBUG*/
> It might help to replace those uses of MAX_STRING_SIZE+1 with
> PVNAME_STRINGSZ.
> Dirk
> Dirk Zimoch wrote:
>> I tested the sequencer with a long name and it seems that it
>> truncates the PV name to 41 chars.
>> A seqChanShow shows the difference between the name used in assign
>> and the actual name used in CA:
>> Channel name: "DZ:45678901234567890123456789012345678901"
>>  Unexpanded (assigned) name: "DZ:
>> 456789012345678901234567890123456789012345678901234567890"
>> Dirk
>> Mark Rivers wrote:
>>> EPICS base defines the maximum length of the PV name to be
>>> PVNAME_STRINGSZ, which is currently 61 including the nil terminator.
>>> What length limitation does the sequencer impose?  Is it more
>>> restrictive than this?
>>> Mark
>>> ________________________________
>>> From: [email protected] on behalf of Patrick Thomas
>>> Sent: Thu 9/3/2009 6:29 PM
>>> Subject: sequencer feature request
>>> Hi,
>>> I was wondering if I could ask for a feature request for the next
>>> version of the sequencer? Is there any chance that it would be
>>> possible
>>> to use unlimited length record names in assign to statements?
>>> Thank you,
>>> Patrick
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: sequencer feature request Eric Norum
sequencer feature request Patrick Thomas
RE: sequencer feature request Mark Rivers
Re: sequencer feature request Dirk Zimoch
Prev: 2eSST??? Eric Bjorklund
Next: RE: 2eSST??? Kalantari Babak
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer feature request Eric Norum
Next: Re: sequencer feature request Eric Norum
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
