1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access security problem
To: GOURNAY Jean-Francois <[email protected]>
Cc: [email protected]
Date: Thu, 10 Sep 2009 07:02:58 -0500
Now that you mention it you are correct, TRUE does correspond to 1 and
not > 0. The CALC must evaluate to 1 or 0 for this to work correctly.
I'm not sure what the logic is for this but it does seem to me that if
the CALC does not evaluate to 1 then it is FALSE.
I was thinking that it was the other way around and that the TRUE
condition meant != 0 rather than = 1.
With the right shift then what happens when the ASGVAL = 6?
When more than 1 bit is set you may need 2 conditions to evaluate the
CALC to TRUE. When you have 6 for example >>1 the value is now 3. I
think that you may need to get the CALC to evaluate to 1 to be TRUE.
Assuming of course that it will be possible your ASGVAL may be some
value other than 1,2,4, or 8.
Marty
GOURNAY Jean-Francois wrote:
Sorry, I still think I am right !
I run my tests on a soft Linux IOC. The asDumpRules cmd seems to be asprules in my case. Here are my results with A=1 and A=2 following Andrew’s suggestion (A& … instead of A >> …).
With A=1 the 1rst RULE for WRITE is TRUE which is OK
With A=2 I A&2 = 2 which is NOT the TRUE value (TRUE corresponds to 1 and not to !=0):
Simulateur >
Simulateur >*dbpf ASGVAL,1*
DBR_LONG: 1 0x1
Simulateur >asprules
ASG(DEFAULT) {
        INPA(ASGVAL) value=1.000000
        RULE(1,READ,NOTRAPWRITE)
*        RULE(1,WRITE,NOTRAPWRITE) {*
*                UAG(tous)*
*                HAG(hag)*
*                CALC("A&1") result=TRUE*        **
                UAG(develop)
                HAG(hag)
                CALC("A&2") result=FALSE
                UAG(physique)
                HAG(hag)
                CALC("A&4") result=FALSE
                UAG(gournay)
                HAG(hag)
                CALC("A&8") result=FALSE
                UAG(epics)
                HAG(hag)
                CALC("A&16") result=FALSE
Simulateur >*dbpf ASGVAL,2*
DBR_LONG: 2 0x2
ASG(DEFAULT) {
        INPA(ASGVAL) value=2.000000
                UAG(tous)
                HAG(hag)
                CALC("A&1") result=FALSE
*                UAG(develop)*
*                HAG(hag)*
*                CALC("A&2") result=FALSE*
                UAG(physique)
                HAG(hag)
                UAG(gournay)
                HAG(hag)
                UAG(epics)
                HAG(hag)
Simulateur >
If now I change the 2nd rule from A&2 to A>>1, I have now TRUE:
DBR_LONG: 2 0x2
ASG(DEFAULT) {
                UAG(tous)
                HAG(hag)
        *RULE(1,WRITE,NOTRAPWRITE) {*
*                UAG(develop)*
*                HAG(hag)*
*                CALC("A>>1") result=TRUE*
                UAG(physique)
                HAG(hag)
                UAG(gournay)
                HAG(hag)
                UAG(epics)
                HAG(hag)
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : Martin L. Smith [mailto:[email protected]]
Envoyé : jeudi 10 septembre 2009 12:50
À : GOURNAY Jean-Francois
Cc : [email protected]
Objet : Re: Access security problem
Actually Andrew is correct. Take the "A&2" as an example, when bit 1 is TRUE
then the result of the CALC is TRUE, when bit 1 is FALSE then the result of
the CALC will be FALSE. TRUE being = 1 and FALSE being = 0.
This may be why you are seeing this problem. If you log into the IOC console
and issue this command you will see the value that CA access security thinks
your CALC expression evaluates to as shown below.
asDumpRules
ASG(ID01ds_ACTION) {
         INPA(ID01ds:AccessSecurity) value=3.000000
         RULE(0,WRITE,TRAPWRITE) {
                 UAG(operator)
                 HAG(local)
                 CALC("A<3") result=FALSE
                 UAG(flcord)
                 HAG(flctrl,local)
                 CALC("A<2") result=FALSE
         RULE(1,WRITE,TRAPWRITE) {
                 UAG(sec01)
                 HAG(sec01)
                 CALC("A<1") result=FALSE
                 UAG(appdev)
Marty
 Dear Andrew,
I think you are wrong. Remember that the CALC expression must return
TRUE or FALSE which will not be the case with A&2, A&4 ...
I guess my scheme is correct. Everything works except this problem
with this spiral2mgr user that I don't understand (see the table below from my previous mail). We will try to overcome it in a way or another ... unless somebody has another idea about it !!!
 J.F. Gournay
 CEA Saclay
 IRFU/SIS
 De : Andrew Johnson [mailto:[email protected]]
 Envoyé : mercredi 9 septembre 2009 16:56
 À : [email protected]
 Cc : GOURNAY Jean-Francois
 On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
> I did more systematic tests and I have this strange situation:
> ASGVAL  UAG      spiral2  spiral2mgr      gournay
> 1       tous      W        W               W        OK
> 2       develop   -        - (should be W) -        WRONG
> 4       physique  W        -               -        OK
> 8       gournay   -        W (should be -) W        WRONG
> W : database WRITE access
> - :  no write access
> I modified the CALC expressions accordingly to Martin suggestion :
> CALC("A&1") instead of CALC("A&1=1").  But I don't think I have to write
> CALC (A>0&&A<2) as my A value comes from a longout record.
 You're right there, but for historical reasons the relative precedence of
 the ">>" and "=" operators are different in C and CALC, so you do need to
 change your expressions:
>             CALC("A&1=1")
 As Marty suggested "A&1" is sufficient here
>             CALC("A>>1=1")
CALC actually evaluates this as "A>>(1=1)" which is not what you
mean.  You
 could use "(A>>1)=1" but I would suggest "A&2" here instead.
>             CALC("A>>2=1")
 "A&4"
>             CALC("A>>3=1")
 "A&8"
 Using fewer operators will also parse and execute faster.
> This message sent yesterday didn't show up.
 That's because you actually sent it to tech-talk-bounces@aps., not to
tech-talk@aps., and I didn't get a chance to forward it manually
before you
 re-sent it.
 HTH,
 - Andrew
J.F. Gournay
CEA Saclay
IRFU/SIS
RE: Access security problem GOURNAY Jean-Francois
Re: Access security problem GOURNAY Jean-Francois
Prev: RE: Killing a soft IOC which doesn't have an interactive shell Mark Rivers
Next: RE: Killing a soft IOC which doesn't have an interactive shell Rees, Nick (DLSLtd,RAL,DIA)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Access security problem GOURNAY Jean-Francois
Next: RE: Access security problem GOURNAY Jean-Francois
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
