1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Access security problem
To: <[email protected]>
Date: Thu, 10 Sep 2009 16:18:29 +0200
To deal with such conditions (several bits in ASGVAL), I changed my rules like this:
CALC("(A>>1)&1") CALC("(A>>2)&1") ...
Now I can have several rules giving a TRUE result
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : Martin L. Smith [mailto:[email protected]]
Envoyé : jeudi 10 septembre 2009 14:03
À : GOURNAY Jean-Francois
Cc : [email protected]
Objet : Re: Access security problem
Now that you mention it you are correct, TRUE does correspond to 1 and
not > 0. The CALC must evaluate to 1 or 0 for this to work correctly.
I'm not sure what the logic is for this but it does seem to me that if
the CALC does not evaluate to 1 then it is FALSE.
I was thinking that it was the other way around and that the TRUE
condition meant != 0 rather than = 1.
With the right shift then what happens when the ASGVAL = 6?
When more than 1 bit is set you may need 2 conditions to evaluate the
CALC to TRUE. When you have 6 for example >>1 the value is now 3. I
think that you may need to get the CALC to evaluate to 1 to be TRUE.
Assuming of course that it will be possible your ASGVAL may be some
value other than 1,2,4, or 8.
Marty
GOURNAY Jean-Francois wrote:
> Sorry, I still think I am right !
> I run my tests on a soft Linux IOC. The asDumpRules cmd seems to be
> asprules in my case. Here are my results with A=1 and A=2 following
> Andrew's suggestion (A& ... instead of A >> ...).
> With A=1 the 1rst RULE for WRITE is TRUE which is OK
> With A=2 I A&2 = 2 which is NOT the TRUE value (TRUE corresponds to 1
> and not to !=0):
> Simulateur >
> Simulateur >*dbpf ASGVAL,1*
> DBR_LONG:           1         0x1
> Simulateur >asprules
> ASG(DEFAULT) {
>         INPA(ASGVAL) value=1.000000
>         RULE(1,READ,NOTRAPWRITE)
> *        RULE(1,WRITE,NOTRAPWRITE) {*
> *                UAG(tous)*
> *                HAG(hag)*
> *                CALC("A&1") result=TRUE*        **
>                 UAG(develop)
>                 HAG(hag)
>                 CALC("A&2") result=FALSE
>                 UAG(physique)
>                 HAG(hag)
>                 CALC("A&4") result=FALSE
>                 UAG(gournay)
>                 HAG(hag)
>                 CALC("A&8") result=FALSE
>                 UAG(epics)
>                 HAG(hag)
>                 CALC("A&16") result=FALSE
> Simulateur >*dbpf ASGVAL,2*
> DBR_LONG:           2         0x2
> ASG(DEFAULT) {
>         INPA(ASGVAL) value=2.000000
>                 UAG(tous)
>                 HAG(hag)
>                 CALC("A&1") result=FALSE
> *                UAG(develop)*
> *                HAG(hag)*
> *                CALC("A&2") result=FALSE*
>                 UAG(physique)
>                 HAG(hag)
>                 UAG(gournay)
>                 HAG(hag)
>                 UAG(epics)
>                 HAG(hag)
> Simulateur >
> If now I change the 2nd rule from A&2 to A>>1, I have now TRUE:
> DBR_LONG:           2         0x2
> ASG(DEFAULT) {
>                 UAG(tous)
>                 HAG(hag)
>         *RULE(1,WRITE,NOTRAPWRITE) {*
> *                UAG(develop)*
> *                HAG(hag)*
> *                CALC("A>>1") result=TRUE*
>                 UAG(physique)
>                 HAG(hag)
>                 UAG(gournay)
>                 HAG(hag)
>                 UAG(epics)
>                 HAG(hag)
> J.F. Gournay
> CEA Saclay
> IRFU/SIS
> Envoyé : jeudi 10 septembre 2009 12:50
> Actually Andrew is correct. Take the "A&2" as an example, when bit 1 is TRUE
> then the result of the CALC is TRUE, when bit 1 is FALSE then the result of
> the CALC will be FALSE. TRUE being = 1 and FALSE being = 0.
> This may be why you are seeing this problem. If you log into the IOC console
> and issue this command you will see the value that CA access security thinks
> your CALC expression evaluates to as shown below.
> asDumpRules
> ASG(ID01ds_ACTION) {
>          INPA(ID01ds:AccessSecurity) value=3.000000
>          RULE(0,WRITE,TRAPWRITE) {
>                  UAG(operator)
>                  HAG(local)
>                  CALC("A<3") result=FALSE
>                  UAG(flcord)
>                  HAG(flctrl,local)
>                  CALC("A<2") result=FALSE
>          RULE(1,WRITE,TRAPWRITE) {
>                  UAG(sec01)
>                  HAG(sec01)
>                  CALC("A<1") result=FALSE
>                  UAG(appdev)
> Marty
>>  Dear Andrew,
>>  I think you are wrong. Remember that the CALC expression must return
> TRUE or FALSE which will not be the case with A&2, A&4 ...
>>  I guess my scheme is correct. Everything works except this problem
> with this spiral2mgr user that I don't understand (see the table below
> from my previous mail). We will try to overcome it in a way or another
> ... unless somebody has another idea about it !!!
>>  J.F. Gournay
>>  CEA Saclay
>>  IRFU/SIS
>>  De : Andrew Johnson [mailto:[email protected]]
>>  Envoyé : mercredi 9 septembre 2009 16:56
>>  À : [email protected]
>>  Cc : GOURNAY Jean-Francois
>>  On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
>> > I did more systematic tests and I have this strange situation:
>> > ASGVAL  UAG      spiral2  spiral2mgr      gournay
>> > 1       tous      W        W               W        OK
>> > 2       develop   -        - (should be W) -        WRONG
>> > 4       physique  W        -               -        OK
>> > 8       gournay   -        W (should be -) W        WRONG
>> > W : database WRITE access
>> > - :  no write access
>> > I modified the CALC expressions accordingly to Martin suggestion :
>> > CALC("A&1") instead of CALC("A&1=1").  But I don't think I have to write
>> > CALC (A>0&&A<2) as my A value comes from a longout record.
>>  You're right there, but for historical reasons the relative precedence of
>>  the ">>" and "=" operators are different in C and CALC, so you do need to
>>  change your expressions:
>> >             CALC("A&1=1")
>>  As Marty suggested "A&1" is sufficient here
>> >             CALC("A>>1=1")
>>  CALC actually evaluates this as "A>>(1=1)" which is not what you
> mean.  You
>>  could use "(A>>1)=1" but I would suggest "A&2" here instead.
>> >             CALC("A>>2=1")
>>  "A&4"
>> >             CALC("A>>3=1")
>>  "A&8"
>>  Using fewer operators will also parse and execute faster.
>> > This message sent yesterday didn't show up.
>>  That's because you actually sent it to tech-talk-bounces@aps., not to
>>  tech-talk@aps., and I didn't get a chance to forward it manually
> before you
>>  re-sent it.
>>  HTH,
>>  - Andrew
> J.F. Gournay
> CEA Saclay
> IRFU/SIS
Re: Access security problem GOURNAY Jean-Francois
Re: Access security problem Martin L. Smith
Prev: RE: sequencer feature request Mark Rivers
Next: Re: sequencer feature request Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Access security problem Martin L. Smith
Next: "buffer over-write" problem with StringIn record Maurizio Montis
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
