Yes, I think your right. I changed the permissions of the folder that I
was creating the ioc in with chmod 777 and it worked. I'm not quite sure
I understand why though. Both the folder that I am putting the ioc in
and the copy of base that I am using are owned by the same user that I
am logged in as. How does this work?
Thank you,
Patrick
Zhichu Chen wrote:
Well, could be a permission problem. Have you tried "sudo"?
On Sat, Sep 19, 2009 at 11:40 AM, Patrick Thomas
<[email protected]> wrote:
Yes, there is a Makefile there.
-Patrick
Zhichu Chen wrote:
Are you sure your "base" is made successfully without any errors? You
can check your base/templates/makeBaseApp/top/iocApp to see if there's
Makefile there. makeBaseApp.pl just copy the files and do some macros
replacements I think.
On Sat, Sep 19, 2009 at 8:42 AM, Patrick Thomas
and I have 3-14-11 instead of 3-14-11-asdl
Eric Norum wrote:
Seems to work here:
norume 233>
/usr/local/iocapps/R3.14.11/base/3-14-11-asd1/bin/darwin-x86/makeBaseApp.pl
-t ioc blah
norume 234> ls -R
Makefile blahApp configure
./blahApp:
Db Makefile src
./blahApp/Db:
Makefile
./blahApp/src:
Makefile blahMain.cpp
./configure:
CONFIG Makefile RULES RULES_DIRS
CONFIG_SITE RELEASE RULES.ioc RULES_TOP
On Sep 18, 2009, at 5:15 PM, Patrick Thomas wrote:
I was trying to run makeBaseApp -t ioc with epics 3-14-11, and I
noticed
that it did not put a Makefile in the directory. It only creates the
application directory and the configure directory. Is this correct?
Thank you,
Patrick
- Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
- makeBaseApp -t ioc missing Makefile Patrick Thomas
- Re: makeBaseApp -t ioc missing Makefile Eric Norum
- Re: makeBaseApp -t ioc missing Makefile Patrick Thomas
Re: Spring Meeting 2010? Ernest L. Williams Jr.
web page for EPICS meeting in Kobe, Oct. 11,2009. Noboru Yamamoto
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
