1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building streamdevice with epics 3.14.11
Cc: [email protected]
Date: Tue, 22 Sep 2009 22:09:13 -0700
Thank you, that include seems to fix it. How would I go about getting a copy of this latest snapshot? Can I download it somewhere?
Mark Rivers wrote:
Hi Patrick,
Sorry, I missed one change that I made for 3.14.11 when I diff the CVS diff. Here it is: Index: StreamDevice-2-4/src/devwaveformStream.c
RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/devwaveformStream.c,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -r1.1 -r1.2
--- StreamDevice-2-4/src/devwaveformStream.c    2008/11/24 18:07:33     1.1
+++ StreamDevice-2-4/src/devwaveformStream.c    2009/08/28 23:42:17     1.2
@@ -19,6 +19,7 @@
#include "devStream.h"
+#include <errlog.h>
 #include <waveformRecord.h>
 #include <string.h>
 #include <epicsExport.h>
Needing to include "errlog.h" in code that previously did not include it is one of the most common changes needed when upgrading to 3.14.11. For completeness I am appending all changes I've made from 2-4 to fix errors and compiler warnings when building on 64-bits. Mark corvette:~/devel/stream/2-4>cvs diff -rR2-4
? configure/RELEASE.win32-x86-debug
cvs server: tag R2-4 is not in file .cvsignore
Index: StreamDevice-2-4/src/AsynDriverInterface.cc
RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/AsynDriverInterface.cc,v
diff -u -r1.1 -r1.2
--- StreamDevice-2-4/src/AsynDriverInterface.cc 2008/11/24 18:07:33     1.1
+++ StreamDevice-2-4/src/AsynDriverInterface.cc 2009/09/01 18:40:37     1.2
@@ -129,9 +129,11 @@
     "asynSuccess", "asynTimeout", "asynOverflow", "asynError"
+#ifndef NO_TEMPORARY
 static const char* eomReasonStr[] = {
     "NONE", "CNT", "EOS", "CNT+EOS", "END", "CNT+END", "EOS+END", "CNT+EOS+END"
+#endif
class AsynDriverInterface : StreamBusInterface
 #ifdef EPICS_3_14
@@ -663,6 +665,16 @@
                 clientName(), pasynUser->errorMessage);
             writeCallback(StreamIoFault);
             return;
+        case asynDisconnected:
+            error("%s: asynDisconnected in write: %s\n",
+                clientName(), pasynUser->errorMessage);
+            writeCallback(StreamIoFault);
+            return;
+        case asynDisabled:
+            error("%s: asynDisabled in write: %s\n",
+            return;
@@ -922,6 +934,15 @@
                 readCallback(StreamIoFault, buffer, received);
                 break;
+                error("%s: asynDisconnected in read: %s\n",
+                readCallback(StreamIoFault, buffer, received);
+                return;
+                error("%s: asynDisabled in read: %s\n",
         if (!readMore) break;
         if (readMore > 0)
Index: StreamDevice-2-4/src/ChecksumConverter.cc
RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/ChecksumConverter.cc,v
diff -u -r1.1 -r1.2
--- StreamDevice-2-4/src/ChecksumConverter.cc   2008/11/24 18:07:33     1.1
+++ StreamDevice-2-4/src/ChecksumConverter.cc   2009/09/01 18:41:28     1.2
@@ -542,9 +542,9 @@
     debug("ChecksumConverter %s: output to check: \"%s\"\n",
         checksumMap[fnum].name, output.expand(start,length)());
- sum = checksumMap[fnum].xorout ^ checksumMap[fnum].func(
+    sum = checksumMap[fnum].xorout ^ (checksumMap[fnum].func(
         reinterpret_cast<uchar*>(output(start)), length,
-        checksumMap[fnum].init) & mask[checksumMap[fnum].bytes];
+        checksumMap[fnum].init) & mask[checksumMap[fnum].bytes]);
debug("ChecksumConverter %s: output checksum is 0x%lX\n",
         checksumMap[fnum].name, sum);
@@ -603,9 +603,9 @@
         return -1;
         reinterpret_cast<uchar*>(input(start)), length,
debug("ChecksumConverter %s: input checksum is 0x%0*lX\n",
         checksumMap[fnum].name, 2*checksumMap[fnum].bytes, sum);
diff -u -r1.1 -r1.2
@@ -19,6 +19,7 @@
 #include <string.h>
Index: configure/RELEASE
RCS file: /net/beams-nfs/export/local/cvs/support/stream/configure/RELEASE,v
retrieving revision 1.3
diff -u -r1.3 RELEASE
--- configure/RELEASE   2008/10/24 19:36:49     1.3
+++ configure/RELEASE   2009/09/23 04:39:45
@@ -9,11 +9,11 @@
 # module defined in the RELEASE file is rebuilt.
SUPPORT=/corvette/home/epics/devel
-ASYN=/corvette/home/epics/devel/asyn/4-10
-CALC=/corvette/home/epics/devel/calc/2-6-5beta
-SSCAN=/corvette/home/epics/devel/sscan/2-6-2
+ASYN=/corvette/home/epics/devel/asyn/4-13
+CALC=/corvette/home/epics/devel/calc/2-8
+SSCAN=/corvette/home/epics/devel/sscan/2-6-6
# EPICS_BASE usually appears last so other apps can override stuff:
-EPICS_BASE=/corvette/usr/local/epics/base-3.14.10
+EPICS_BASE=/corvette/usr/local/epics/base-3.14.11
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
Index: configure/RELEASE.win32-x86
RCS file: /net/beams-nfs/export/local/cvs/support/stream/configure/RELEASE.win32-x86,v
diff -u -r1.3 RELEASE.win32-x86
--- configure/RELEASE.win32-x86 2008/10/24 19:36:49     1.3
+++ configure/RELEASE.win32-x86 2009/09/23 04:39:45
@@ -9,10 +9,10 @@
SUPPORT=J:/epics/devel
-ASYN=J:/epics/devel/asyn/4-10
-CALC=J:/epics/devel/calc/2-6-5beta
-SSCAN=J:/epics/devel/sscan/2-6-2
+ASYN=J:/epics/devel/asyn/4-13
+CALC=J:/epics/devel/calc/2-8
+SSCAN=J:/epics/devel/sscan/2-6-6
-EPICS_BASE=H:/epics/base-3.14.10
+EPICS_BASE=H:/epics/base-3.14.11
Sent: Tue 9/22/2009 11:30 PM
To: Mark Rivers
Sorry, forgot to cc this to tech-talk.
I am also using 2-4, on linux-x86-64.
I get the following error:
make -C ./src install make[1]: Entering directory
`/users/thomas/test/modules/StreamDevice/StreamDevice-2-4/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[2]: Entering directory
`/users/thomas/test/modules/StreamDevice/StreamDevice-2-4/src/O.linux-x86_64'
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT
-O3 -Wall -m64 -g -fPIC -I. -I../O.Common -I. -I..
-I../../../include/os/Linux -I../../../include
-I/users/thomas/test/modules/sncseq-2.0.12/include
-I/users/thomas/test/modules/asyn-4.12/include
-I/users/thomas/test/base/base-3-14-11/include/os/Linux
-I/users/thomas/test/base/base-3-14-11/include ../devwaveformStream.c
../devwaveformStream.c: In function 'readData':
../devwaveformStream.c:52: warning: implicit declaration of function
'errlogSevPrintf'
../devwaveformStream.c:52: error: 'errlogFatal' undeclared (first use in
this function)
../devwaveformStream.c:52: error: (Each undeclared identifier is
reported only once
../devwaveformStream.c:52: error: for each function it appears in.)
../devwaveformStream.c:132: error: 'errlogMajor' undeclared (first use
in this function)
../devwaveformStream.c: In function 'writeData':
../devwaveformStream.c:184: error: 'errlogFatal' undeclared (first use
in this function)
make[2]: *** [devwaveformStream.o] Error 1
make[2]: Leaving directory
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory
make: *** [src.install] Error 2
Thank you,
Patrick
Mark Rivers wrote:
I have built streamDevice 2-4 with 3.14.11 with no problems.  This is the version of streamDevice in the synApps module, but I think the code for devwaveformStream.c should be the same.  What version of streamDevice are you using, on what platform, and what is the error?
From: [email protected] on behalf of Patrick Thomas
Sent: Tue 9/22/2009 10:44 PM
To: [email protected]
Subject: building streamdevice with epics 3.14.11
Has anyone else had any trouble building the stream device module with
epics base 3-14-11? I seem to get compile errors on running make with
reference to ../devwaveformStream.c
Thank you,
Patrick
RE: building streamdevice with epics 3.14.11 Mark Rivers
building streamdevice with epics 3.14.11 Patrick Thomas
Re: building streamdevice with epics 3.14.11 Patrick Thomas
Prev: RE: building streamdevice with epics 3.14.11 Mark Rivers
Next: RE: building streamdevice with epics 3.14.11 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
