1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: building streamdevice with epics 3.14.11
To: "Patrick Thomas" <[email protected]>
Cc: [email protected]
Date: Wed, 23 Sep 2009 01:17:31 -0500
I just made a CVS snapshot:
http://cars.uchicago.edu/software/pub/streamHEAD.tgz
Sent: Wed 9/23/2009 12:09 AM
To: Mark Rivers
Subject: Re: building streamdevice with epics 3.14.11
Thank you, that include seems to fix it. How would I go about getting a
copy of this latest snapshot? Can I download it somewhere?
Mark Rivers wrote:
> Hi Patrick,
> Sorry, I missed one change that I made for 3.14.11 when I diff the CVS diff.  Here it is:
> Index: StreamDevice-2-4/src/devwaveformStream.c
> RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/devwaveformStream.c,v
> retrieving revision 1.1
> retrieving revision 1.2
> diff -u -r1.1 -r1.2
> --- StreamDevice-2-4/src/devwaveformStream.c    2008/11/24 18:07:33     1.1
> +++ StreamDevice-2-4/src/devwaveformStream.c    2009/08/28 23:42:17     1.2
> @@ -19,6 +19,7 @@
>  #include "devStream.h"
> +#include <errlog.h>
>  #include <waveformRecord.h>
>  #include <string.h>
>  #include <epicsExport.h>
> Needing to include "errlog.h" in code that previously did not include it is one of the most common changes needed when upgrading to 3.14.11.
> For completeness I am appending all changes I've made from 2-4 to fix errors and compiler warnings when building on 64-bits.
> Mark
> corvette:~/devel/stream/2-4>cvs diff -rR2-4
> ? configure/RELEASE.win32-x86-debug
> cvs server: tag R2-4 is not in file .cvsignore
> Index: StreamDevice-2-4/src/AsynDriverInterface.cc
> RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/AsynDriverInterface.cc,v
> diff -u -r1.1 -r1.2
> --- StreamDevice-2-4/src/AsynDriverInterface.cc 2008/11/24 18:07:33     1.1
> +++ StreamDevice-2-4/src/AsynDriverInterface.cc 2009/09/01 18:40:37     1.2
> @@ -129,9 +129,11 @@
>      "asynSuccess", "asynTimeout", "asynOverflow", "asynError"
> +#ifndef NO_TEMPORARY
>  static const char* eomReasonStr[] = {
>      "NONE", "CNT", "EOS", "CNT+EOS", "END", "CNT+END", "EOS+END", "CNT+EOS+END"
> +#endif
>  class AsynDriverInterface : StreamBusInterface
>  #ifdef EPICS_3_14
> @@ -663,6 +665,16 @@
>                  clientName(), pasynUser->errorMessage);
>              writeCallback(StreamIoFault);
>              return;
> +        case asynDisconnected:
> +            error("%s: asynDisconnected in write: %s\n",
> +                clientName(), pasynUser->errorMessage);
> +            writeCallback(StreamIoFault);
> +            return;
> +        case asynDisabled:
> +            error("%s: asynDisabled in write: %s\n",
> +            return;
> @@ -922,6 +934,15 @@
>                  readCallback(StreamIoFault, buffer, received);
>                  break;
> +                error("%s: asynDisconnected in read: %s\n",
> +                readCallback(StreamIoFault, buffer, received);
> +                return;
> +                error("%s: asynDisabled in read: %s\n",
>          if (!readMore) break;
>          if (readMore > 0)
> Index: StreamDevice-2-4/src/ChecksumConverter.cc
> RCS file: /net/beams-nfs/export/local/cvs/support/stream/StreamDevice-2-4/src/ChecksumConverter.cc,v
> diff -u -r1.1 -r1.2
> --- StreamDevice-2-4/src/ChecksumConverter.cc   2008/11/24 18:07:33     1.1
> +++ StreamDevice-2-4/src/ChecksumConverter.cc   2009/09/01 18:41:28     1.2
> @@ -542,9 +542,9 @@
>      debug("ChecksumConverter %s: output to check: \"%s\"\n",
>          checksumMap[fnum].name, output.expand(start,length)());
> -    sum = checksumMap[fnum].xorout ^ checksumMap[fnum].func(
> +    sum = checksumMap[fnum].xorout ^ (checksumMap[fnum].func(
>          reinterpret_cast<uchar*>(output(start)), length,
> -        checksumMap[fnum].init) & mask[checksumMap[fnum].bytes];
> +        checksumMap[fnum].init) & mask[checksumMap[fnum].bytes]);
>      debug("ChecksumConverter %s: output checksum is 0x%lX\n",
>          checksumMap[fnum].name, sum);
> @@ -603,9 +603,9 @@
>          return -1;
>          reinterpret_cast<uchar*>(input(start)), length,
>      debug("ChecksumConverter %s: input checksum is 0x%0*lX\n",
>          checksumMap[fnum].name, 2*checksumMap[fnum].bytes, sum);
> diff -u -r1.1 -r1.2
> @@ -19,6 +19,7 @@
>  #include <string.h>
> Index: configure/RELEASE
> RCS file: /net/beams-nfs/export/local/cvs/support/stream/configure/RELEASE,v
> retrieving revision 1.3
> diff -u -r1.3 RELEASE
> --- configure/RELEASE   2008/10/24 19:36:49     1.3
> +++ configure/RELEASE   2009/09/23 04:39:45
> @@ -9,11 +9,11 @@
>  # module defined in the RELEASE file is rebuilt.
>  SUPPORT=/corvette/home/epics/devel
> -ASYN=/corvette/home/epics/devel/asyn/4-10
> -CALC=/corvette/home/epics/devel/calc/2-6-5beta
> -SSCAN=/corvette/home/epics/devel/sscan/2-6-2
> +ASYN=/corvette/home/epics/devel/asyn/4-13
> +CALC=/corvette/home/epics/devel/calc/2-8
> +SSCAN=/corvette/home/epics/devel/sscan/2-6-6
>  # EPICS_BASE usually appears last so other apps can override stuff:
> -EPICS_BASE=/corvette/usr/local/epics/base-3.14.10
> +EPICS_BASE=/corvette/usr/local/epics/base-3.14.11
>  TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
> Index: configure/RELEASE.win32-x86
> RCS file: /net/beams-nfs/export/local/cvs/support/stream/configure/RELEASE.win32-x86,v
> diff -u -r1.3 RELEASE.win32-x86
> --- configure/RELEASE.win32-x86 2008/10/24 19:36:49     1.3
> +++ configure/RELEASE.win32-x86 2009/09/23 04:39:45
> @@ -9,10 +9,10 @@
>  SUPPORT=J:/epics/devel
> -ASYN=J:/epics/devel/asyn/4-10
> -CALC=J:/epics/devel/calc/2-6-5beta
> -SSCAN=J:/epics/devel/sscan/2-6-2
> +ASYN=J:/epics/devel/asyn/4-13
> +CALC=J:/epics/devel/calc/2-8
> +SSCAN=J:/epics/devel/sscan/2-6-6
> -EPICS_BASE=H:/epics/base-3.14.10
> +EPICS_BASE=H:/epics/base-3.14.11
> ________________________________
> From: Patrick Thomas [mailto:[email protected]]
> Sent: Tue 9/22/2009 11:30 PM
> To: Mark Rivers
> Sorry, forgot to cc this to tech-talk.
> I am also using 2-4, on linux-x86-64.
> I get the following error:
> make -C ./src install make[1]: Entering directory
> `/users/thomas/test/modules/StreamDevice/StreamDevice-2-4/src'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
> make[2]: Entering directory
> `/users/thomas/test/modules/StreamDevice/StreamDevice-2-4/src/O.linux-x86_64'
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT
> -O3 -Wall -m64 -g -fPIC -I. -I../O.Common -I. -I..
> -I../../../include/os/Linux -I../../../include
> -I/users/thomas/test/modules/sncseq-2.0.12/include
> -I/users/thomas/test/modules/asyn-4.12/include
> -I/users/thomas/test/base/base-3-14-11/include/os/Linux
> -I/users/thomas/test/base/base-3-14-11/include ../devwaveformStream.c
> ../devwaveformStream.c: In function 'readData':
> ../devwaveformStream.c:52: warning: implicit declaration of function
> 'errlogSevPrintf'
> ../devwaveformStream.c:52: error: 'errlogFatal' undeclared (first use in
> this function)
> ../devwaveformStream.c:52: error: (Each undeclared identifier is
> reported only once
> ../devwaveformStream.c:52: error: for each function it appears in.)
> ../devwaveformStream.c:132: error: 'errlogMajor' undeclared (first use
> in this function)
> ../devwaveformStream.c: In function 'writeData':
> ../devwaveformStream.c:184: error: 'errlogFatal' undeclared (first use
> in this function)
> make[2]: *** [devwaveformStream.o] Error 1
> make[2]: Leaving directory
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory
> make: *** [src.install] Error 2
> Thank you,
> Patrick
> Mark Rivers wrote:
>> I have built streamDevice 2-4 with 3.14.11 with no problems.  This is the version of streamDevice in the synApps module, but I think the code for devwaveformStream.c should be the same.  What version of streamDevice are you using, on what platform, and what is the error?
>> Mark
>> From: [email protected] on behalf of Patrick Thomas
>> Sent: Tue 9/22/2009 10:44 PM
>> To: [email protected]
>> Subject: building streamdevice with epics 3.14.11
>> Hi,
>> Has anyone else had any trouble building the stream device module with
>> epics base 3-14-11? I seem to get compile errors on running make with
>> reference to ../devwaveformStream.c
>> Thank you,
>> Patrick
building streamdevice with epics 3.14.11 Patrick Thomas
RE: building streamdevice with epics 3.14.11 Mark Rivers
Re: building streamdevice with epics 3.14.11 Patrick Thomas
Prev: Re: building streamdevice with epics 3.14.11 Patrick Thomas
Next: New: 14-bit EPICS oscilloscopes Boyd Shaw
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
