1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: db folder
Cc: [email protected]
Date: Wed, 23 Sep 2009 15:38:09 -0700
I'm sorry, I don't quite follow, where do I put the .db files that will be loaded by the ioc? Do I have to put something in one of the Makefiles?
Andrew Johnson wrote:
On Wednesday 23 September 2009 16:23:54 Patrick Thomas wrote:
Does makeBaseApp -t ioc normally create a db folder in the top
directory, or does that get made by the user?
Neither; directories such bin, db, dbd, doc, html, include, and lib will get created at build time when make has something that needs to be installed in the relevant directory. Note that if you do a 'make distclean' at the top level, these directories *and their contents* will be deleted, so it is a bad idea to add files to them manually as they might not have a very long life.
HTH,
- Andrew
RE: db folder Mark Rivers
RE: db folder [SEC=UNCLASSIFIED] LYNCH, Damien
Re: db folder Ralph Lange
db folder Patrick Thomas
Re: db folder Andrew Johnson
Prev: Re: db folder Andrew Johnson
Next: RE: db folder Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
