1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: db folder [SEC=UNCLASSIFIED]
To: "Patrick Thomas" <[email protected]>
Cc: [email protected]
Date: Thu, 24 Sep 2009 09:24:45 +1000
Add your .db files the xxxApp/Db directory. Then modify the DB += line
in the Makefile in that directory. The make system will copy the .db
files from xxxApp/Db to the db/ directory. Make will create the db/
directory if it does not exist. Doing a make distclean (or uninstall) in
your top directory will remove the db/ directory but the xxxApp/Db/x.db
file will still exist.
Damien
> -----Original Message-----
> From: [email protected]
[mailto:[email protected]]
> On Behalf Of Patrick Thomas
> Sent: Thursday, 24 September 2009 8:38 AM
> To: Andrew Johnson
> Subject: Re: db folder
> I'm sorry, I don't quite follow, where do I put the .db files that
will
> be loaded by the ioc? Do I have to put something in one of the
Makefiles?
> Andrew Johnson wrote:
> > On Wednesday 23 September 2009 16:23:54 Patrick Thomas wrote:
> >> Does makeBaseApp -t ioc normally create a db folder in the top
> >> directory, or does that get made by the user?
> > Neither; directories such bin, db, dbd, doc, html, include, and lib
will
> get
> > created at build time when make has something that needs to be
installed
> in
> > the relevant directory.  Note that if you do a 'make distclean' at
the
> top
> > level, these directories *and their contents* will be deleted, so it
is
> a bad
> > idea to add files to them manually as they might not have a very
long
> life.
> > HTH,
> > - Andrew
db folder Patrick Thomas
Re: db folder Andrew Johnson
Re: db folder Patrick Thomas
Prev: RE: db folder Mark Rivers
Next: Re: db folder Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: db folder Tim Mooney
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
