1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm handler on base 3-14-11
To: Patrick Thomas <[email protected]>
Cc: Thomas Birke <[email protected]>, [email protected]
Date: Thu, 24 Sep 2009 11:27:20 -0400
just to roll it up, but it's a little bit weird Patrick's build failed on linking, one would have expect it to happen earlier when it cannot find the headers that are normally come in the dev packages.
Does alh actually uses curses? I remember it as an X11/Xm app.
I am thinking the real issue might be too many default options in extensions/configure
Matthieu
On 09/24/09 02:19, Patrick Thomas wrote:
Thank you everyone!
Thomas Birke wrote:
Mark Rivers wrote:
lrwxrwxrwx 1 root root 27 Feb 20 2008 /usr/lib64/libncurses.so ->
../../lib64/libncurses.so.5
And that's the one, the linker needs to find during linking.
On a Debian system, for every library like ncurses5, there's also a
"dev" package that you have to install if you want to use the library
for development purpose.
This "dev" package (libncurses5-dev) is the one, that draws the
necessary sym-links needed to link own programs to the
libncurses-library.
Maybe it's something like this, that's causing the problem...
Thomas
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
alarm handler on base 3-14-11 Patrick Thomas
RE: alarm handler on base 3-14-11 Mark Rivers
Re: alarm handler on base 3-14-11 Patrick Thomas
Re: alarm handler on base 3-14-11 Zhichu Chen
Re: alarm handler on base 3-14-11 Matthieu Bec
Prev: Re: gnumake <arch> does not filter out unwished targets on R3.14.11 Andrew Johnson
Next: Re: db folder Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm handler on base 3-14-11 Patrick Thomas
Next: Re: alarm handler on base 3-14-11 Thomas Birke
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
