1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: db folder
To: Patrick Thomas <[email protected]>
Cc: "[email protected] Techtalk" <[email protected]>
Date: Fri, 25 Sep 2009 17:54:31 -0500
A common way of handling this is with:
	template/substitution files so that each IOC has its own .db file
or
one .db file loaded by all IOCs with different macro definitions in the dbLoadRecords commands.
On Sep 25, 2009, at 5:48 PM, Patrick Thomas wrote:
What should I do if I have multiple iocs under the same top directory, and they all use a common .db file? Is there a similar Db directory to put them in that is not specific to one application?
Thank you,
Patrick
Mark Rivers wrote:
You can put entries in the xxxApp/Db/Makefile, and then make will copy the .db files to the TOP/db directory. But you don't have to do this if you don't want to, you can have the IOC directly load the .db files out of the xxxApp/Db directory. The latter is what I do, because I deploy EPICS on sites where they don't have a build system, and so can't run make. So we just use the .db files in the Db/ directory.
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/23/2009 5:38 PM
To: Andrew Johnson
Cc: [email protected]
I'm sorry, I don't quite follow, where do I put the .db files that will be loaded by the ioc? Do I have to put something in one of the Makefiles?
Andrew Johnson wrote:
On Wednesday 23 September 2009 16:23:54 Patrick Thomas wrote:
Does makeBaseApp -t ioc normally create a db folder in the top
directory, or does that get made by the user?
Neither; directories such bin, db, dbd, doc, html, include, and lib will get created at build time when make has something that needs to be installed in the relevant directory. Note that if you do a 'make distclean' at the top level, these directories *and their contents* will be deleted, so it is a bad idea to add files to them manually as they might not have a very long life.
HTH,
- Andrew
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
db folder Patrick Thomas
Re: db folder Andrew Johnson
Re: db folder Patrick Thomas
RE: db folder Mark Rivers
Prev: Re: db folder Patrick Thomas
Next: Re: db folder Jason Tiller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
