You can turn off the error messages completely with
asynSetTraceMask("L3", 0)
I don't think you can only print connection status change messages.
Right now the asyn trace mask bits are:
#define ASYN_TRACE_ERROR 0x0001
#define ASYN_TRACEIO_DEVICE 0x0002
#define ASYN_TRACEIO_FILTER 0x0004
#define ASYN_TRACEIO_DRIVER 0x0008
#define ASYN_TRACE_FLOW 0x0010
I have been thinking that it would be good to add
ASYN_TRACE_WARNING
which would print messages for conditions that are less severe than ASYN_TRACE_ERROR, but still not "normal" which is when ASYN_TRACE_FLOW should print.
I don't think that would solve your problem though, since presumably you would like to see a message on reconnect, which would not be characterized as an error or warning.
From: [email protected] on behalf of Benjamin Franksen
Sent: Fri 10/16/2009 7:34 AM
To: [email protected]
Subject: asyn messages
The log files of some of our IOCs are spammed with failed reconnect messages
like this:
[Fri Oct 16 09:30:15 2009]2009/10/16 09:30:15.139
asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
[Fri Oct 16 09:30:21 2009]2009/10/16 09:30:21.147 L3 vxiConnectPort error
gpibc1cp.mlscs.bessy.de: RPC: Remote system error - No route to host
[Fri Oct 16 09:30:21 2009]2009/10/16 09:30:21.147 L3 -1 autoConnect could
not connect
[Fri Oct 16 09:30:27 2009]2009/10/16 09:30:27.156 L3 vxiConnectPort error
whenever e.g. a gpib box is turned off.
Is there a way to tell asyn to shut up and output mesasages only when
connection status changes?
Cheers
Ben
- asyn messages Benjamin Franksen
Re: StripTool build errors: SDDS.h? Janet
<2009>
Incorrect get_precision Schoeneburg, Bernd
<2009>
