1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: can't initialize record field with string
To: haquin <[email protected]>
Cc: [email protected]
Date: Tue, 27 Oct 2009 09:54:25 -0500
haquin wrote:
Hi Tim,
Thank you for your proposal but:
I looked in the genSub record code and I think that what I do should work ... After deeper investigations, it turns out that when I initialize the INPH field type with FTH=STRING or CHAR it is then assigned a CA_LINK type ((*plinkin).type)==CA_LINK instead of CONSTANT ...
That's why the Constant string is not copied at init.
When FTH=LONG then ((*plinkin).type)==CONSTANT
How can I force it to be a CONSTANT
I think the only way to make the link type CONSTANT is to make the
link value entirely numeric.  As I read the code, FTH should have no
effect on the link type, because the EPICS code that makes the decision
doesn't look at anything other than the link value.
Tim Mooney a écrit :
haquin wrote:
I initialize the INPH (with macro substitution) of a gensub record with a string,
but it is never transferred to the corresponding H variable ...
in the IOC shell I use the commands:
epics> dbgf MyGensub.INPH
       DBR_STRING:          MyString NPP NMS
epics> dbgf MyGensub.H
       DBR_STRING:
The behaviour is different if I use LONG instead of STRING ...
Can someone tell me how to do retreive MyString in MyGensub.H ?
You can use a stringout record to hold the string, like so:
record(stringout, "myStringInit") {
   field(VAL, "$(MYSTRINGMACRO)")
   field(UDF, "0")
record(aSub, "myASub") {
   field(INPH, "myStringInit")
Then, dbLoadRecords("myDatabase.db", "MYSTRINGMACRO=MyString")
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
can't initialize record field with string haquin
Re: can't initialize record field with string Tim Mooney
Re: can't initialize record field with string haquin
Prev: Re: can't initialize record field with string haquin
Next: Re: can't initialize record field with string Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
