1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: can't initialize record field with string
To: [email protected]
Date: Tue, 27 Oct 2009 09:56:53 -0500
Hi Christophe,
On Tuesday 27 October 2009 05:50:55 haquin wrote:
> I looked in the genSub record code and I think that what I do should work
> ... After deeper investigations, it turns out that when I initialize the
> INPH field type with FTH=STRING or CHAR it is then assigned a CA_LINK type
> ((*plinkin).type)==CA_LINK instead of CONSTANT ... That's why the Constant
> string is not copied at init.
> When FTH=LONG then ((*plinkin).type)==CONSTANT
> How can I force it to be a CONSTANT
You can't; with the existing database code the link type will be CONSTANT only
if the INPH string is a number.  This behavior is a fundamental feature of the
way in which we parse link strings: If the string is completely consumed by
strtod() or strtol() the link type is a CONSTANT; if not and it matches the
name of a local PV it's a DB_LINK, otherwise it must be a CA_LINK.
As an alternative to Tim's suggestion you could put one or more dbpf commands
in your startup script to set the .H field with your string(s), but they must
appear after the iocInit command.
Sorry,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: can't initialize record field with string haquin
Re: can't initialize record field with string Tim Mooney
Prev: Re: can't initialize record field with string Tim Mooney
Next: ICALEPCS 2009 Lifetime Achievement Award Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: can't initialize record field with string haquin
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
