1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: can't initialize record field with string
To: haquin <[email protected]>
Cc: [email protected]
Date: Tue, 27 Oct 2009 12:21:16 -0500
Hi Christophe,
On Tuesday 27 October 2009 10:38:06 haquin wrote:
> But can you still answer the following questions:
> - is it possible to initialize an array with a MACRO (be it numeric or
> string) ? - is it possible to initialize a string array from the startup
> script using dbpf command or else ?
No, it is not currently possible to initialize array fields before iocInit
(that includes using dbLoadRecords), since the memory to store the array data
is not allocated until the record initialization takes place.  The best
suggestion the community has for doing this is to use an autosave/restore
program to set the array during the IOC start-up.  That could also be used to
set string fields.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
can't initialize record field with string haquin
Re: can't initialize record field with string Andrew Johnson
Re: can't initialize record field with string haquin
Prev: Re: can't initialize record field with string haquin
Next: Re: can't initialize record field with string Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
