I just looked more carefully at the error message when the Prosilica driver crashed and you were running under gdb:
>>Program received signal SIGSEGV, Segmentation fault.
>>[Switching to Thread 0xb749fb90 (LWP 22434)]
>>0x080fdb23 in SIGAction ()
>>(gdb) bt
>>#0 0x080fdb23 in SIGAction ()
>>#1 0x08248bdd in ignoreSigAlarm (signal=14) at ../../../src/libCom/osi/os/posix/osdSignal.cpp:109
>>#2 <signal handler called>
>>#3 0x00110416 in __kernel_vsyscall ()
>>#4 0x007543d1 in select () from /lib/libc.so.6
>>#5 0x080fdf0e in pPvMultiplexer::Body ()
>>#6 0x08101af0 in _ThreadFunction ()
>>#7 0x0082651f in start_thread (arg=0xb749fb90) at pthread_create.c:297
>>#8 0x0075c04e in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:130
>>(gdb)
This is a known bug in EPICS base R3-14-10 on Linux with Posix signal handling. It is fixed in R3-14-11, or you can patch 3-14-10. Unfortunately it is not described on the 3-14-10 known problems page, and there is no official patch for it. However, I have a patch file I will send you separately.
This problem is described in a previous tech-talk message:
http://www.aps.anl.gov/epics/tech-talk/2009/msg00420.php
and in the release notes for areaDetector R1-4:
http://cars9.uchicago.edu/software/epics/areaDetectorReleaseNotes.html
My driver should work fine with the Prosilica GC780. The Axis products are very different from the Prosilica cameras. They stream compressed video (M-JPEG, MPEG-4, etc.), rather than uncompressed images. They are more typically used for surveillance than for scientific data acquisition.
- error building mca6-11 Silver
- RE: error building mca6-11 Davidsaver, Michael
- Re: RE: error building mca6-11 Silver
- Re: error building mca6-11 Bruce Hill
- RE: error building mca6-11 Mark Rivers
- Re: RE: RE: error building mca6-11 Silver
- Re: RE: RE: RE: error building mca6-11 Silver
SNL Question: dynamic assignment and event flag Kim, Kukhee
<2009>
2025
Leybold Vacuum INIVAC IM540 David Dudley
<2009>
2025
