1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fwd: CA link behavior
Cc: [email protected]
Date: Wed, 09 Dec 2009 10:58:26 +0100
Hi Andrew,
My personal opinion is that a record which is not processed should not "do" anything. That means it should not cause other records to process and should not change their value. I think the original idea behind processing a record is that this is the only time where a record is "active". Maybe apart from the time when it initializes. But even then it should not process other records.
Let's assume this situation:
ioc1:
A
B.OUT-> C
ioc2:
C
D.INP -> A
I think the "correct" behavior is:
When ioc2 reboots, C becomes INVALID/UDF and only gets a copy of B when B processes. D gets initialized with a copy of A. Neither C nor D gets processed unless they have PINI set.
Dirk
Andrew Johnson wrote:
Hi Geoff,
On Monday 23 November 2009 16:52:43 Geoff Savage wrote:
Here are the details of my testing with a summary preceding.
Thanks for that very helpful and detailed bug report. For others, I'll quote Geoff's original message to explain what's happening:
On Friday 13 November 2009 13:38:36 Geoff Savage wrote:
I have a passive stringout record in IOC A whose OUTLINK references an
mbbo record in IOC B.  When I reboot IOC B the value in the stringout
record is written to the mbbo record even though the stringout record
has not been processed.
I have confirmed that exactly the same thing occurs with the latest release, and after studying the history of the code it looks like this behavior may date all the way back to 1996.
The good news is that it only happens when the data type used is a string, so if you replace your stringout with a longout or another mbbo it will stop happening. That changes the coupling between your two IOCs slightly since you've moved the string to state conversion, but it doesn't really increase it because the strings had to match before anyway.
The bad news is that it looks like Marty intended this to happen for all data types, as he went to the trouble of storing a copy of the data and recording the fact that the link had actually been used. In practice non-string output links don't re-send their last value on reconnection because the link flag bit pvlOptOutNative never actually gets set anywhere in the code.
The question at this point is whether to change the current behavior for string data. Given that EPICS users are not used to this my inclination is to stop it happening for strings too, but I'm open to argument on that. In the future we might add a link flag to allow the DB designer to control whether this should occur, so I will probably leave the implementation in place anyway and just disable it for now.
Any comments?
- Andrew
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Re: Fwd: CA link behavior Ralph Lange
Re: CA link behavior Andrew Johnson
Fwd: CA link behavior Geoff Savage
Re: Fwd: CA link behavior Andrew Johnson
Prev: RE: Asyn On Cygwin Pawel Kowalski - BiRa Systems Inc.
Next: RE: Support for PI C863 Gabadinho Jose
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: CA link behavior Andrew Johnson
Next: Re: Fwd: CA link behavior Ralph Lange
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
