1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Remote I/O
To: <[email protected]>
Date: Thu, 17 Dec 2009 15:33:15 +0900
Hi Nick Rees,
>  3. Standard PLC systems where (as distinct from the other two), you
> take Ethernet to a PLC controller which then has a series of modules
it
> talks to in a variety of possible ways.
I recommend FA-M3 PLC made by YOKOGAWA.
The product line has a CPU, F3RP61(e-RT3 2.0), that runs Linux.
You can run iocCore on the CPU to make it an IOC.
A simple device support module, which was created just by wrapping the
BSP's API, has already been available.
http://www-linac.kek.jp/cont/epics/f3rp61/
Channel Access takes care of the communication between the IOC and OPI
tools running on your host machine.
Simple DI/DO and AD/DA modules, positioning module, temperature monitor
module, etc. are avalable for the IOC.
What would you have to say to this solution?
Best regards,
J. Odagiri, KEKB control group
Prev: RE: Remote I/O Andrew C. Starritt
Next: RE: Rethinking asyn motor drivers Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Remote I/O Chris Timossi
Next: Updated 8, 12 ,13 and 14-bit EPICS scopes Boyd Shaw
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
