1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Remote I/O
Date: Thu, 17 Dec 2009 16:43:37 +1100
Hi all,
  This is true. We build the entire Storage Ring Schneiders PLCs from XML files out of our source repository.
  By the way, the XML files thenselves are generated from Excel spread sheets, files exported out of UnityPro
itself and files gnerated by a bespoke program that processes a 'simple' text file.
Andrew Starritt
Principal Controls Engineer
Australian Synchrotron
800 Blackburn Road, Clayton, Victoria 3168, Australia
Tel: + 61 3 8540 4164    Fax: + 61 3 8540 4200
E-mail: [email protected]
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, December 17, 2009 4:21 AM
To: Rolf Keitel; David Dudley
Cc: [email protected]
I am pretty sure the Australian Synchrotron uses the XML files with the Schneiders, so they can keep the source code in a conventional code management system.
Sent: Wed 12/16/2009 11:07 AM
To: David Dudley
Subject: Re: Remote I/O
David,
Any reason why you excluded Schneider from your evaluation? If I'm not mistaken, their Unity programming software (which we don't use for historical reasons) uses XML files.
- rolf -
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Remote I/O David Dudley
Re: Remote I/O Rolf Keitel
RE: Remote I/O Mark Rivers
Prev: RE: Remote I/O Richard Farnsworth
Next: Re: Remote I/O jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Remote I/O Andreas Balzer
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
