1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Remote I/O
To: Matthias Clausen <[email protected]>
Date: Thu, 17 Dec 2009 08:08:48 -0500
At the FEL here at JLAB, we have several newer systems running Omron C-Series PLCs. The systems currently running are the Laser Personal Safety System, Turning Mirror Cassettes (motor control for optics), and our UV vacuum system. The PLCs are all programmed over Ethernet using Omron's CX-Programmer and an EPICS Ethernet driver is used for communication to the PLCs memory. I've not had much hassle in maintaining an IOC app and PLC logic for a given system. Usually the logic is only on one side depending on the requirements. I've scripted the creation of address files for generating the db. The address file created contains all the memory mapping and comments, providing great documentation of each system. Haven't heard this mentioned, but one other benefit we have deployed was the use of touchscreens for interactions with these PLC systems. For the minimal programming required, they have been a valuable resource in the flexibility they provide for local and remote control (using serial and Ethernet).
Wesley
Matthias Clausen wrote:
Hi Bob,
Dalesio, Leo wrote:
This ability to define the PLC code and logic in ASCII was the primary reason identified by David Dudley in our choice for AB over Siemens and Yokogawa. Yokogawa has responded that they plan to add this ability.
Matthias - are you saying that you can do this with the Siemens PLC? Can you define the logic in ASCII as well?
I am sorry - it is not the logic itself but the memory layout of all the nodes on the Profibus (including the memory layout of the PLC) which we configure with a CSS tool. This generates a XML files which gets loaded to the IOC. This was possible because we have the driver source code in our hands. Using the Siemens tools you will generate a binary file which will be loaded to the hardware board by some Windows DLLs - so no way to get this running on Linux or vxWorks :-(
Why would you want to cerate an ASCII file of the actual logic? Isn't this loaded via Ethernet to the PLC or burned into EPROM? Or are you loading the code to the PLCs via an IOC?
The cost of keeping the PLC software in synch with the IOC was considered significant.
There's a payload on both sides - the PLC and the IOC.
You need to map PLC-IO into the memory of the (PLC) communication controller and map another time the memory in the dual ported RAM on the IOC into EPICS record addresses. Both configurations (except the PLC program itself) can be handled with our solution.
Cheers
Matthias
-----Original Message-----
From: [email protected] <mailto:[email protected]> on behalf of Matthias Clausen
Sent: Wed 12/16/2009 10:02 AM
To: Ralph Lange
Cc: EPICS Tech Talk
Hi Ralph,
Ralph Lange wrote:
> On Wed 16 Dec 2009 8:16:17 Matthias Clausen wrote:
>> Hi Nick,
>> [...] In our case sensors and actors are directly connected to
>> Profibus. The remaining I/O is connected through WaGo I/O with a
>> Profibus controller. Profibus driver and configuration is available
>> from us - even with redundancy support...
> Hi Matthias,
> is that using the 1996 IPAC-Profibus Interface that is listed in the
> hardware support database on the EPICS web site?
no - it's a new driver which support the Softing PC 104 cards. Softing
is now producing also a Compact PCI card for us.
There's a special firmware available which supports redundant Profibus
connections and fail-over - in conjunction with the redundant IOC.
Configuring Profibus (DP - or PA) is quite complicated. You have to map
memory space of the I/O devices into the DPM on the IOC. So you need to
configure your records's addresses in a way that they match with the DMP
layout.
We have developed a configuration tool in CSS which creates an XML file.
(Like the Siemens 'Step 7' tool) This file is parsed on the IOC and
creates the memory layout in the DPM. The EPICS records get their
Profibus address from a reference in the configuration database. (When
the db files gets created)
We should finally write some documentation about it ;-))
Thanks
-Matthias
> Ralph
Matthias Clausen                         Cryogenic Controls Group(MKS-2)
phone:  +49-40-8998-3256                Deutsches Elektronen Synchrotron
fax:    +49-40-8994-3256                                    Notkestr. 85
e-mail: [email protected] <mailto:[email protected]> 22607 Hamburg
WWW-MKS2.desy.de                                                 Germany
begin:vcard
fn:Wesley Moore
n:Moore;Wesley
org:Thomas Jefferson National Accelerator Facility;Free Electron Laser
adr:Suite 19, MS 18;;12000 Jefferson Avenue;Newport News;VA;23606;USA
email;internet:[email protected]
title:FEL Computer Scientist
tel;work:(757) 269-6033
tel;fax:(757) 269-6384
tel;pager:(757) 584-6033
url:http://www.jlab.org/FEL/
version:2.1
end:vcard
Re: Remote I/O Paul Hamadyk
Remote I/O nick.rees
Re: Remote I/O Matthias Clausen
Re: Remote I/O Ralph Lange
RE: Remote I/O Dalesio, Leo
Prev: RE: Rethinking asyn motor drivers Mark Rivers
Next: Re: Remote I/O David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Remote I/O Matthias Clausen
Next: Re: Remote I/O Paul Hamadyk
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
