1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Remote I/O
To: Wesley Moore <[email protected]>
Date: Thu, 17 Dec 2009 13:26:30 +0000
On Thu, 2009-12-17 at 08:08 -0500, Wesley Moore wrote:
> At the FEL here at JLAB, we have several newer systems running Omron
> C-Series PLCs.  The systems currently running are the Laser Personal
> Safety System, Turning Mirror Cassettes (motor control for optics), and
> our UV vacuum system.  The PLCs are all programmed over Ethernet using
> Omron's CX-Programmer and an EPICS Ethernet driver is used for
> communication to the PLCs memory.  I've not had much hassle in
> maintaining an IOC app and PLC logic for a given system.  Usually the
> logic is only on one side depending on the requirements.  I've scripted
> the creation of address files for generating the db.  The address file
> created contains all the memory mapping and comments, providing great
> documentation of each system.  Haven't heard this mentioned, but one
> other benefit we have deployed was the use of touchscreens for
> interactions with these PLC systems.  For the minimal programming
> required, they have been a valuable resource in the flexibility they
> provide for local and remote control (using serial and Ethernet).
> Wesley
We also use Omron PLCs, mostly CJ1s, and communicate using Hostlink or
FINS (Factory Interface Network Service) in a Hostlink wrapper via the
serial port (using streams and asyn). I am just performing some speed
comparisons between the serial port and the ETN21 Ethernet module using
FINS/UDP and FINS/TCP.
You say that "an EPICS Ethernet driver is used for communication to the
PLCs memory". Is that via FINS?
Paul.
Re: Remote I/O Wesley Moore
Remote I/O nick.rees
Re: Remote I/O Matthias Clausen
Re: Remote I/O Ralph Lange
RE: Remote I/O Dalesio, Leo
Prev: Re: Remote I/O David Dudley
Next: Re: Remote I/O Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Remote I/O Wesley Moore
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
