While installing the medm 3.1.3 on 64 bit Fedora 11 operation system, I got following compilation error. gcc -ansi -pedantic -D_POSIX_C_SOURCE=199506L -O3 -Wall -DEDITRES -D_X86_64_ -Dlinux -fPIC -D_REENTRANT -DUNIX -D_BSD_SOURCE -I. -I.. -I../../printUtils -I../../xc -I -I -I../../../../include/os/Linux -I../../../../include -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include/os/Linux -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include -c ../utils.c ../utils.c: In function 'doRubberbanding': ../utils.c:965: warning: cast from pointer to integer of different size ../utils.c: In function 'doDragging': ../utils.c:1160: warning: cast from pointer to integer of different size ../utils.c: In function 'doPasting': ../utils.c:1400: warning: cast from pointer to integer of different size ../utils.c: In function 'doResizing': ../utils.c:1658: warning: cast from pointer to integer of different size ../utils.c: In function 'parseAndExecCommand': ../utils.c:4268: warning: the address of 'command' will always evaluate as 'true' ../utils.c:4743:2: error: #error getEventType only works for LASTEvent=35 (See X.h) make[2]: *** [utils.o] Error 1 make[2]: Leaving directory `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm/O.linux-x86_64' make[1]: *** [buildInstall.linux-x86_64] Error 2 make[1]: Leaving directory `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm' make: *** [medm.buildInstall] Error 2 I am using epics-base 3.14.11 and could you please help me in fixing this issue. Best Regards, Ramu
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
