Hello Ben,
Some of the old vxi11.x implementations were designed assuming
long=32bit. If I remember correctly, VXI-11 document was one of
them. I had to modify it for 64bit architecture some time ago.
As we didn't modify AsynDriver, I hope this is not the issue :-).
We run ~30 oscilloscopes of DPO7104/7254 at KEKB and KEK linac.
As they have good CPUs inside (~3GHz), we run embedded IOCs on
all of them. While VXI-11 on DPO7000 is relatively fast, an
embedded IOC with a dedicated (synchronous) device-support is
faster and more reliable.
(Before this implementation I was afraid of the stability of
Windows. However, this embedded IOC turned out to be rather
reliable.)
Cheers,
Kazuro.
>>> On Wed, 17 Mar 2010 13:09:33 JST, Benjamin Franksen <[email protected]> wrote;
> On Wednesday 17 March 2010, Benjamin Franksen wrote:
> > I'm trying to talk to the mentioned scope via asyn/stream and get
> > mysterious crashes the first time the IOC tries to communicate over the
> > link. Below is a trace of the IOC shell up to the crash. I am using the
> > latest and greatest versions of everything except EPICS base:
> > base-3.14.8.2, asyn-4.11a (supposedly the last version that works with
> > base-3.14.8), StreamDevice-2- snapshot20081007. The crash happens on the
> > latest ubuntu version as well as on a debian stable system. I should
> > point out that with the exact same setup I can talk fine with e.g. a
> > GPIB controller.
> Ok I did dome more research. G旦tz suggested valgrind and indeed I got
> interesting results:
> (1) When I run the IOC under valgrind it doesn't crash, it even talks to the
> device. Nice.
> (2) Valgrind complains about StreamDevice doing "Mismatched free() / delete
> / delete []". See below for a transcript.
> My current theory is that these mismatched calls cause the memory free list
> to become corrupted. Note that VXI-11 is based on RPC which heavily uses
> malloc/free internally during runtime, so there is some probability that a
> corrupted free list will lead to a crash inside the RPC library.
> Dirk, could you look into this?
> Cheers
> Ben
> PS: this is a log of the IOC shell run under valgrind:
(* log removed *)
Kazuro FURUKAWA <[email protected]>
Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
Telephone: +81-29-864-5200 x4316, Facsimile: +81-29-864-0321
- Re: Tektronic Scope DPO7254 over VXI-11 crashes IOC Benjamin Franksen
RE: Help Request: Setting up NIXI-1042/NI-MXI-4/DXP-XMAP withdxpStandalone_2-10 David Ehle
what is the withMPF.dbd? 汪启胜
<2010>
<2010>
