1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cac_select_io Segmentation fault
To: "'Al Honey'" <[email protected]>, <[email protected]>
Date: Wed, 7 Apr 2010 08:38:18 -0600
Aloha Allan,
Ø  Does the seg fault occur because r3.13.10 is NOT thread safe?
The R3.13 CA Client library is definitely __not__ thread safe, and I can easily imagine that this might be the cause of your seg fault.
Ø  Does anyone have an example of a multi-threaded app using r3.13.10 on UNIX?
The R3.14 CA client library _is_ thread safe, and it should also interoperate fine with R3.13 IOCs. We routinely operate LANSCE with that configuration in our production system. Our control room runs R3.14, but many of our IOCs still run R3.13. You should read the section in the reference manual entitled “Thread Safety and Preemptive Callback to User Code“.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of Al Honey
Sent: Tuesday, April 06, 2010 5:57 PM
To: [email protected]
Subject: cac_select_io Segmentation fault
Aloha
I am trying to get a multi-threaded application working on SunOs 5.10 with connection to two UNIX IOC’s.
I get a seg fault for ellDelete, two statements from the end of cac_select_io() (epics/r3.13.10/base/src/ca/bsd_depen.c).
The seg fault does not occur immediately but within a couple of minutes (connections are to two IOC’s running on UNIX, with events from two long records on each IOC, where one record on each system is updated at 1 hz and the other at 10 hz).
Allan
RE: cac_select_io Segmentation fault Jeff Hill
cac_select_io Segmentation fault Al Honey
Prev: Re: EDM text entry: segmentation fault Dmitry Teytelman
Next: Re: EDM text entry: segmentation fault Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cac_select_io Segmentation fault Andrew Johnson
Next: RE: cac_select_io Segmentation fault Jeff Hill
