1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cac_select_io Segmentation fault
To: [email protected]
Date: Wed, 7 Apr 2010 16:29:10 -0500
Hi Allen,
On Wednesday 07 April 2010 15:57:28 Al Honey wrote:
> > I don't think the CA client
> > interface changed too much between 3.13 and 3.14.
> Okay, that is good :)
> I will start researching the differences.
I would suggest starting by just trying to compile your code against 3.14.11.
I believe the CA Reference manual no longer documents all of the deprecated
API calls but the code still supports most if not all of them.  You will need
to make changes if you have multiple threads making CA calls, but for many
single-threaded client applications I believe a recompile can be sufficient.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
cac_select_io Segmentation fault Al Honey
Re: cac_select_io Segmentation fault Ralph Lange
RE: cac_select_io Segmentation fault Al Honey
Prev: RE: cac_select_io Segmentation fault Al Honey
Next: RE: cac_select_io Segmentation fault Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
