Andrew Johnson wrote:
On Monday 12 April 2010 14:53:09 Ralph Lange wrote:
Through Channel Access: Not that I know.
John Maclean wrote a Perl script called capr that does this to some extent,
but it's rather old now (2003), relies on the command-line program caget (but
not the one that comes with Base), and as you would expect can only display
those fields of a record that are accessible through CA. It has to parse a
DBD file to work out what fields each record type has, but it has a default
path and will also read an environment variable so you don't have to specify
the path every time. I can provide a copy if anyone is interested, but it
will probably need some effort to get it working at another site.
I thought Kay Kasemir had included a tool like this into CSS at one point, but
I might be wrong about that.
Andrew,
I would appreciate it if you could send capr.
Yes, CSS includes PVTree which is similar.
John
- Re: command line tool to list all field values of a Record ? Kasemir, Kay
- command line tool to list all field values of a Record ? John Dobbins
- Re: command line tool to list all field values of a Record ? Ralph Lange
- Re: command line tool to list all field values of a Record ? Andrew Johnson
Re: command line tool to list all field values of a Record ? Tim Mooney
<2010>
2025
<2010>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
