1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: command line tool to list all field values of a Record ?
To: John Dobbins <[email protected]>, Andrew Johnson <[email protected]>
Date: Mon, 12 Apr 2010 17:36:32 -0400
Hi:
As mentioned, Channel Access doesn't tell you what fields a record might
have. You have to parse the DBD file that your IOC loaded.
> Yes, CSS includes PVTree which is similar.
The CSS PV Tree,
http://sourceforge.net/apps/trac/cs-studio/wiki/EPICSPVTree, uses Channel
Access to read .RTYP, then uses a configurable table to read more fields
depending on the record type, for example INPA, INPB, INPC, ... for calc
records, and tries to figure out if those in turn contain what looks like
another record name, which it then reads recursively.
In addition we have a "PV Fields" tool for CSS, see
http://sourceforge.net/apps/trac/cs-studio/wiki/PVFieldsViewer ,
that displays all the configured fields of a record,
Value in the original DB file as well as current value,
based on IRMIS-type data in the RDB.
Kay
RE: command line tool to list all field values of a Record ? Debby Quock
Re: command line tool to list all field values of a Record ? John Dobbins
Prev: Re: command line tool to list all field values of a Record ? Tim Mooney
Next: RE: command line tool to list all field values of a Record ? Debby Quock
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: command line tool to list all field values of a Record ? John Dobbins
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
