1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epics debian repository update
To: [email protected]
Date: Wed, 19 May 2010 14:36:58 -0500
On Wednesday 19 May 2010 13:55:26 Davidsaver, Michael wrote:
> I wonder if relocating the tree under '/usr/lib/epics/' (like
> /usr/lib/gcc/) or '/opt/epics' would be more acceptable?  Though I would
> definitely say that the long term solution is making the EPICS build
> system more flexible with respect to filesystem layout.
The FHS suggests /opt/epics/<package> as the best location (although I admit
that epics is not currently a LANANA registered provider name).  See
http://www.pathname.com/fhs/pub/fhs-2.3.html#OPTADDONAPPLICATIONSOFTWAREPACKAGES
for what it says about /opt.  That is where I usually install the code for
training courses.
The FHS document also says:
    Large software packages must not use a direct subdirectory under the
    /usr hierarchy.
About /usr/lib it says:
    /usr/lib includes object files, libraries, and internal binaries that
    are not intended to be executed directly by users or shell scripts.
this /usr/lib/epics would not be appropriate for many things.
The best FOSS code is written to be read by other humans -- Harald Welte
Re: epics debian repository update Bill Lavender
epics debian repository update Davidsaver, Michael
RE: epics debian repository update Davidsaver, Michael
Prev: Re: epics debian repository update Benjamin Franksen
Next: Re: epics debian repository update J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: epics debian repository update Bill Lavender
