1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: linking to shared objects user libraries
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 09 Jul 2010 10:17:20 -0500
On 7/9/10 9:58 AM, Pierrick Hanlet wrote:
> Thanks for the quick responses.
> Yes, I did STATIC_BUILD=NO and SHARED_LIBRARIES=YES
> in xxx/configure/CONFIG_SITE.
> Where might these be overwritten?
They could be overridden anywhere, but one possibility is in your IOC's
configure/CONFIG_SITE or configure/CONFIG.
On a Unix OS in a Bourne shell, you can find possible references like this:
$ cd configure
$ grep STATIC_BUILD *
$ grep SHARED_LIBRARIES *
> Also, since I'm using a
> mixture of static and shared object libraries, will this
> configuration fix me to one type of library or another?
I don't know how this will work.
Lewis
linking to shared objects user libraries Pierrick Hanlet
Re: linking to shared objects user libraries J. Lewis Muir
Re: linking to shared objects user libraries Pierrick Hanlet
Prev: Re: VxWorks 6.7, MV5500 Re: EPICS R3.14.11, sequencer 2.0.12 crash on device support write error Andrew Johnson
Next: Re: VxWorks 6.7, MV5500 Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: RE: linking to shared objects user libraries Davidsaver, Michael
Next: Getting value of a PV from a subRecord function ppredki
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
